Hi Darren
You don't have to use Duck Duck Go on the Pi (it's just the default), you can navigate to the www address of whatever search engine does work on your network. To answer your questions:
D O Sullivan wrote: ↑Tue Jan 30, 2018 2:46 pm
1. Some of the target areas my students are interested in photographing are at high latitudes. Above what line of latitude is beyond the range of the ISS camera?
The ISS orbit is inclined at 51.6 degrees relative to the equator, so that just means it will go 51.6 degrees north of the equator and 51.6 degrees south of it. This
page has a good explanation of the orbit and some great pictures which illustrate it.
2. Re: the images that show the photosynthetic activity of plants. Are the images taken as normal with the blue filter during the mission and after the mission the images taken are then coded by the students to display photosynthetic activity?
Yes, usually you just need to run the image acquisition code on the ISS - which runs on the NoIR camera with the blue filter and later when you get the data back you can post process it using whatever tools you like. There's really no point to processing it in flight.
3. In what folder should the images be stored? (Additionally all photos will be stamped with team name, coordinates and time taken.)
Please just save them in the same folder as your Python code files, we modify the output folder slightly when we prepare your code for flight.
I hope this helps!
Dave
