G-Virus
i2c-dev does not create an i2c-* in /dev
Tue Jan 30, 2018 12:55 am
Hello everyone. I'm configuring my own linux image for RaspberryPi 2B from the official linux kernel 4.9.78-v7+ for Raspberry. I've done and it works but I have a problem with i2c interface.
I have two strings in /etc/sysconfig/modules file:
# I2C interface
i2c-dev
i2c-bcm2708
Also I have i2c-dev built as module. At startup the module is loading successfully but I can't see any i2c-* devices in /dev directory. I've tried to remove the module and insert it again. It shows the following output:
root@raspberry: ~ # modprobe i2c-dev
[  112.440052] i2c /dev entries driver
root@raspberry: ~ #
but there is no any i2c devices in /dev as before.
I have dtparam=i2c_arm=on enabled in config.txt and I don't have any special rules for udev in /etc/udev/rules.d/. Please guys, your ideas what the problem?
Thanks in advance
G-Virus
Re: i2c-dev does not create an i2c-* in /dev
Wed Jan 31, 2018 11:14 pm
It is definitely because of kernel or modules or firmware. I just downloaded PiLFS image and replaced boot parition except cmdline and config files, replaced /lib/modules and /lib/firmware then rebooted Raspberry and i2c-1 has appeared. What could be disabled in the default configuration of Raspberry Linux Kernel 4.9.78?
ivannaz
Wed Feb 13, 2019 3:24 pm
I have this same behavior.
I dare to say that:
- if you build the master branch of the buildroot system, as of today or last week, accepting everything default, and only adding userspace programs;
- add
dtparam=i2c_arm=on
dtparam=spi=on
at the end of config.txt,
and boot, you do not get /dev/i2c anything. You could modprobe i2c-dev to no avail (despite the one line dmesg entry). Neither help modprobing i2c-bcm2708.
lsmod gives then:
Module                  Size  Used by    Not tainted
i2c_bcm2708            16384  0
i2c_dev                16384  0
ipv6                  434176 18 [permanent]
and yet no i2c entries on /dev/
I also wonder what is missing.
DirkS
Wed Feb 13, 2019 4:33 pm
Which OS / kernel version?
I don't see i2c_bcm2708, but i2c_2835 on both Pi 0 and 3b
Don't know if it makes a difference though...
If you're not running standard Raspbian (Lite) using an RPF image then I would suggest you take your spare SD card and install that first.
Enable i2c using raspi-config
ivannaz
Wed Feb 13, 2019 7:45 pm
Yes, thank you.
modprobe i2c-bcm2835 did the trick.
Somehow I associated the "2835" with some older pi versions, and have not tried it before.
6by9
Wed Feb 13, 2019 9:17 pm
i2c_bcm2708 is the old driver, i2c_bcm2835 is the newer one.
Return to “Advanced users”
