must-be
where do i buy a fan for this nes case?
Thu Jan 25, 2018 10:49 am
https://www.amazon.com/functional-POWER ... ords=NESPI
and how to connect it?
i live in israel.
thanks
piglet
Re: where do i buy a fan for this nes case?
Thu Jan 25, 2018 10:58 am
I can't answer your question, as although I've used raspberry pi boards in cases for years I've never seen a need for a fan.
So, to answer a question with a question: do you need a fan?
pcmanbob
Thu Jan 25, 2018 11:34 am
First question does the case have provision for a fan to be fitted, that will dictate size, if not you need to figure out were you can mount one and that will dictate size.
you can get small 5V fans from amazon, eBay and many other online stores.
If you just want it running all the time connect it to the 5V and Ground pins on the gpio header, if you want to control speed & on/off you will need a transistor circuit to switch the 5V.
must-be
Thu Jan 25, 2018 12:29 pm
do you live in a hot country with hot summer days?
and thanks!
must-be
Thu Jan 25, 2018 12:32 pm
i think the size is specified here.
do i need to make the air in or out?
pcmanbob
Thu Jan 25, 2018 2:38 pm
if you have a size specification then that's what you need to take in to account when looking for your fan
blowing cool air in to a case is probably the normal way of doing it.
must-be
Thu Jan 25, 2018 3:05 pm
thanks
but how do i connect the cable and where to find the right screws?
also, will the pi need more electricity because of this?
pcmanbob
Thu Jan 25, 2018 3:14 pm
You need to connect the fan wires red to 5v black to ground
5V and ground pins shown here
and on this
The fan should not draw much current so as long as you are using a good quality 2 - 2.5A psu you should be ok.
screws will depend on what's required by the fan/case buy them from the same place you get the fan.
davidcoton
Thu Jan 25, 2018 9:17 pm
Hot air rises, so let the fan blow the same way rather than fighting it. I doubt it makes much difference, though.
Signature retired
runboy93
Thu Jan 25, 2018 10:10 pm
Just go for cheap aluminum case, cost around 10 dollars. More effective and less noise :D
And if you use WiFi, recommended to use adapter with aluminum case.
HawaiianPi
Fri Jan 26, 2018 1:46 am
Keep in mind that small fans are noisy, and they'll eventually fill your system with dust. That case certainly looks cool, but if you want your system to actually run cool, without the noise and dust associated with fans, get a Flirc case.
The top and sides are a single cast aluminum piece that makes contact with the SoC (CPU+GPU), so the case itself acts like a huge heatsink. No noise, no dust, just a cool running (and pretty cool looking) Raspberry Pi3B computer. Click on picture to go to Amazon product page.
joeygbsn
Fri Jan 26, 2018 3:02 pm
https://www.amazon.com/gp/aw/d/B01M16KD ... VC3MWHA2NJ
This was linked on the Amazon page you posted. Not entirely sure about the fit but looks about right. Looks like a pretty nice case. A few reviews complained about broken usb cables inside, but it looks like it would be easy to fix with a soldering iron.
must-be
Fri Jan 26, 2018 4:04 pm
should i install a heatsink if not a fan for the summer times?
HawaiianPi
Sat Jan 27, 2018 2:30 am
A heatsink inside a case without a fan will only delay overheating slightly. If you insist on using that case, then a heatsink and fan would be best, but a fan alone will work better than a heatsink alone.
Of course this all assumes you are going to be running a Pi3 very hard and want maximum performance. Under normal use a Pi3 won't overheat often, and it will throttle down to protect itself it if does. If you are not planning on pushing your Pi3 super hard for an extended period of time, then you might not need either.
Imperf3kt
Sun Jan 28, 2018 9:26 pm
All I have to do is open the web browser and my Pi will throttle, so there is no need to 'push the pi super hard', all you need to do is use it under normal circumstances.
Having said this, a heatsink alone should be enough.
Although it is not a Raspberry Pi, I cool another SBC with a 15mmx15mm slotted aluminium heatsink. The board is sealed inside an acrylic travel soap holder.
After several hours of 100% CPU load, the temperature is rarely above 45℃
I expect the Pi (which runs 20℃ cooler without a heatsink) should perform just as well.
55:55:44:44:4C
52:4C:52:42:41
must-be
Tue Jan 30, 2018 9:24 pm
i'm using the pi 2
so well... i will consider the fan in case i will install a heatsink
i've already ordered a heatsink but i will not install it for now...
thanks to all of you
