Radu79
Raspistill taking too long
Sun Jan 21, 2018 9:54 pm
I am not sure if this is a bug or something, but using "raspistill -o cam.jpg" takes about 6-7 seconds.
For a long time I thought that this is the time it needs to transfer the image, process it, write it to SD, etc. But it still seemed to be too long, so I did a little experiment. I started a stopwatch app on my phone, and started it at the same time I pressed the enter key, then pointed it towards the camera. The picture shows the stopwatch at 5 seconds... So for the first 5 seconds, the camera app does what exactly? Is there any way to make it faster?
Radu79
Re: Raspistill taking too long
Sun Jan 21, 2018 10:32 pm
Well, I found out that by default there was a 5 seconds delay, just because. I am not sure who thought it would be a good idea to add that as a default option. Anyway, to disable it, just add --timeout 1 and the delay is gone.
6by9
Mon Jan 22, 2018 9:34 am
The delay will have gone, as has any opportunity for auto exposure and auto white balance to do any adaptation to the scene, so expect incorrectly exposed and coloured images.
If you want a delay of 1 then you need to specify a manual shutter speed (-ss) and gains (-ag and -dg) on your command line, and have tightly controlled lighting to your scene. White balance can be forced to run on the capture frame by adding "-st" to the command line, or set to manual with "-awb off -awbg <red gain>,<blue gain>".
Mon Jan 22, 2018 10:00 am
In addition to 6by9 comment, a timeout of about 1000 (1s) is usually enough for all the automated algorithms to settle down, depending on light that can be reduced further, but trail and error will find the best number.
BTW, I chose 5s as the default just because. Long enough for all auto exposures to complete, long enough to adjust camera to be pointing correctly, but not too long to get annoying.
Radu79
Mon Jan 22, 2018 11:15 am
Isn't there a way to automatically detect when the camera finished detecting the light and AWB, and then trigger the capture?
6by9
Mon Jan 22, 2018 11:48 am
It never finishes as such. The algorithm recomputes on every frame (approx every third for AWB) to produce a new set of numbers for subsequent frames. You need a pretty tightly controlled scene to end up with zero variation between frames.
You could set a threshold below which the scene is judged to be the same, but making that work under all situations is a pain. What if your scene has flicker due to the mains frequency of your lights? Or it has motion that shifts the histogram?
If you want to see the numbers, then add "-set" to your command line and it'll print out every change to exposure time, analogue gain, digital gain, and the red and blue gains for white balance.
Bas75
Thu May 17, 2018 11:00 am
I really like the raspistill app, it has many usefull features. However, for my experiment I need to detect change in a very tightly controlled scene. I have followed the pointers given in these posts to come up with the following commandline options:
Command line:
raspistill -p 1000,50,640,480 -t 1 -ISO 400 -ss 750000 -e png -set -awb off -awbg 1.5,1.2 -ag 1.5,1.2 -dg 1.0,1.0 -w 640 -h 480 -o timelapse_0.png
The idea is to always have exactly the same camera behavior, and change is not introduced because of image processing.
However, when I observe the API calls, and look at the preview images I see that:
1) raspiostill will always take one frame for calculations,
2) sometimes raspistill will overrule the analog/digital gain values, resulting in a huge change
API:
mmal: Exposure now 749969, analog gain 1928/256, digital gain 91/256
mmal: AWB R=384/256, B=307/256
mmal: Exposure now 749969, analog gain 1873/256, digital gain 256/256
Perhaps the gain settings I am trying to apply do not make sense?
I hope you can help me with setting the proper parameters, an example will be great!
UPDATE: After looking through the source code that I got from GIT, I was able to experiment a bit. It turned out that not raspistill is performing the multiple captures but the underlying mmal. With some trial and and (t)error I was able to figure out that at least the following options don't work together:
1) The -iso option seems to be emulated using the analog gain. Therefore specifying an ISO value overrides the -ag argument.
2) At some point I found that using the -md 7 argument (sensor in 640x480 mode) significantly speeds up the image capturing. Unfortunately using the -md 7 argument breaks whatever value is set for the shutterspeed using the -ss argument.
Taking these things into account I have managed to construct a set of arguments that seems to be providing a camera configuration that remains the same regardless of the scene being photographed.
raspistill -p 1000,50,640,480 -t 1 -ss 750000 -e png -set -awb off -awbg 1.5,1.2 -ag 1.5,1.2 -dg 1.0,1.0 -w 640 -h 480 -o test.png
Return to “Advanced users”
