I have a portable hard drive that I have set up as a samba share. I am accessing it through a windows 10 machine. Everything is working as it should except during certain circumstances - let me explain. I have raspbian set up to boot to terminal instead of pixel because I like to be able to go directly to pixel or to my Retropie setup with a few keystrokes. When I first boot I cannot access the portable drive share, it is only when I start pixel that am I able to do this. Interestingly though, I am still able to access the samba share folders that were setup by Retropie for Rom access regardless of this (in terminal or pixel). It is also probably worth mentioning that the drive is automatically mounted in /media/pi/.
Does anybody have any insight into this behavior? Ultimately I would like to be able to access the samba share regardless if pixel is running.
