chetuk
how to control speed of dc motor connected to pi & l298n ?
Sun Jan 21, 2018 11:47 am
How to control speed of dc motor connected to pi & l298n ?
Feels robo is too fast and getting out of control to sense line ..
/Chetan S.
PeterO
Re: how to control speed of dc motor connected to pi & l298n ?
Sun Jan 21, 2018 11:55 am
This might give you some ideas
https://github.com/CamJam-EduKit/EduKit ... ration.pdf
PeterO
chetuk
Sun Jan 21, 2018 12:01 pm
Thanks !! PeterO
/Chetan
chetuk
Mon Jan 29, 2018 4:57 pm
this is my code the robo run too fast ...please help to add code so to slower down speed as i desire/???
#!/usr/bin/python
import RPi.GPIO as GPIO #Import GPIO library
from espeak import espeak
import time
#Import time library
GPIO.setwarnings(False)
#set GPIO numbering mode and define output pins
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7,GPIO.OUT)
GPIO.setup(11,GPIO.OUT)
GPIO.setup(13,GPIO.OUT)
GPIO.setup(15,GPIO.OUT)
GPIO.setup(37,GPIO.OUT) # Trigger
GPIO.setup(24,GPIO.IN) # Echo
time.sleep(1)
print "Ultrasonic Measurement"
GPIO.output(37, False)
def measure():
time.sleep(0.333)
GPIO.output(37, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(24)==0:
start = time.time()
while GPIO.input(24)==1:
stop = time.time()
elapsed = stop-start
distance = (elapsed * 34300)/2
return distance
def stop():
GPIO.output(7,False)
GPIO.output(11,False)
GPIO.output(13,False)
GPIO.output(15,False)
def forward():
GPIO.output(7,True)
GPIO.output(13,True)
def back():
GPIO.output(11,True)
GPIO.output(15,True)
def left():
GPIO.output(7,True)
def right():
try:
while True:
distance = measure()
print "Distance : %.1f" % distance
time.sleep(0.0)
if distance >= 130:
forward()
else:
stop()
except KeyboardInterrupt:
#cleanup the GPIO pins before ending
GPIO.cleanup()
OutoftheBOTS
Mon Jan 29, 2018 8:14 pm
at the moment your just turning on your gpio pin to activate the l298n to make the motor spin at full speed. instead you need to use PWM duty cycle on that pin to adjust the speed needed
google "raspbery pi pwm duty cycle"
chetuk
Mon Feb 12, 2018 6:10 am
Any suggestion in code i tried search in google but confused .
/Chetan S.
pcmanbob
Mon Feb 12, 2018 11:16 am
to control the motor speed on your L298N you simply need to appy a PWM signal to the ena & enb inputs ( you may need to remove the jumps from these pins )
this is an example of PWM controlling a fan speed but it will work exactly the same for your motor speed control.
#!/usr/bin/env python2.7
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setup(25, GPIO.OUT)
fan = GPIO.PWM(25, 100)
print "start"
fan.start(0)
sleep (5)
print "Run 100%"
fan.ChangeDutyCycle(100)
sleep (5)
print "Run 50%"
fan.ChangeDutyCycle(50)
sleep (5)
print "Run 25%"
fan.ChangeDutyCycle(25)
sleep(5)
print "Stop"
fan.stop()
GPIO.cleanup()
and please when posting code use code tags
Add [code] at the top
code goes here
and [/code] at the bottom.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
chetuk
Wed Feb 14, 2018 7:44 am
Thanks! pcmanbob
Manage to achieve speed control
Cheers!
arindamsingha
Thu Jan 03, 2019 2:40 pm
Dear Chetuk sir, could you please send me your demo code, I have tried all the processes available on the internet for using PWM signal to control the speed of the motor, but none of this is worked. I will be really grateful if you kindly give me your demo code, just to control the speed through PWM using a raspberry pi. Just give me a reply, I'll give you my email id.
Thanx in advance.
pcmanbob
Fri Jan 04, 2019 1:18 pm
Thanx in advance.
It might help if you show us your code and tell us how you tried to enable speed control , on most L298N motor controllers you only have to apply a PWM signal to the ENA & ENB pins on the motor control board to get speed control.
on this example the pins are marked " A enable " & " B enable " you would need to remove the existing jumpers if fitted as on this example board.
please when you post code use code tags
code goes here
Erklei
Sun Jan 06, 2019 9:30 am
If you apply PWM to enable pin you get the motor run-coast-run-coast-run-coast.
If you apply PWM to input pin you get the motor run-brake-run-brake-run-brake
Be also aware that L298 is only good for motors with running current less than lets say 1A. Its big energy waster and tends to overheat and shut down.
