Mettauk
Reading GPIO states via web interface - php
Wed Jan 17, 2018 5:31 pm
I have the following code in a php page that will switch a relay on or off and tells me when its done.
But, when I open the page I can't tell the current state (high or low, 0 or 1). Can someone guide me how to include a call to read and display current state of a GPIO?
<p><form method="get" action="switch.php">
                <input type="submit" value="ON" name="on">
                <input type="submit" value="OFF" name="off">
        </form>
<?php
        $setmode17 = shell_exec("/usr/local/bin/gpio -g mode 17 out");
        if(isset($_GET['on'])){
                $gpio_on = shell_exec("/usr/local/bin/gpio -g write 17 1");
                echo "Heater is on";
As humans we have been the same for a very very long time, technology changes how we do, not who we are as people.
Re: Reading GPIO states via web interface - php
Wed Jan 17, 2018 6:56 pm
You can get the current value like this
$status = shell_exec("/usr/local/bin/gpio -g read 17");
$status will now contain 1 (on) or 0 (off).
Mettauk
Wed Jan 17, 2018 7:27 pm
Thank you, it works sort of now, I am trying to use that result for something like...
        if $status = 0 ;
                echo "WOW its O";
        else if $status = 1 ;
                echo "OH no its 1";
I Which does not work but I don't know the correct method
EDIT... found it sort of I think but it does not seem to update on a page refresh or reload with no form data?
        if ($status = "0") {
                echo "WOW its O";
        else if ($status = "1") {
                echo "OH no its 1";
Am I confusing High and Low with 0 and 1 which indicate in or out? it seems to be stuck showing 1 with the GPIO is high or low? (Relay open or closed)
I have a different css script that updates an html page on refresh or click to show a differing button colour as
        		#gpio17.HIGH {
        				background-color: Red;
        				color: White;
        		#gpio17.LOW {
        				background-color: Gray;
        				color: Black;
but this is not in php and i'm getting very confused. :(
