ok guys look.
Supra you are asking me to use the picamera library but i have tried to merge both codes and i came up with this
# import the necessary packages
from picamera.array import PiRGBArray
from picamera import PiCamera
import time
import cv2
import numpy as np
import argparse
import datetime
import imutils
import math
width = 800
textIn = 0
textOut = 0
firstFrame = None
def testIntersectionIn(x, y):
res = -450 * x + 400 * y + 157500 #450 400 157500
if((res >= -550) and (res < 550)):
print (str(res))
return True
return False
def testIntersectionOut(x, y):
res = -450 * x + 400 * y + 180000
if ((res >= -550) and (res <= 550)):
print (str(res))
return True
return False
# initialize the camera and grab a reference to the raw camera capture
camera = PiCamera()
camera.resolution = (640, 480)
camera.framerate = 50
camera.hflip = True
rawCapture = PiRGBArray(camera, size=(640, 480))
# allow the camera to warmup
time.sleep(0.1)
# capture frames from the camera
for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
(grabbed, frame) = frame.array #This is the part that it has error
text = "Unoccupied"
if not grabbed:
break
frame = imutils.resize(frame, width=width)
gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
gray = cv2.GaussianBlur(gray, (21, 21), 0)
if firstFrame is None:
firstFrame = gray
continue
frameDelta = cv2.absdiff(firstFrame, gray)
thresh = cv2.threshold(frameDelta, 25, 255, cv2.THRESH_BINARY)[1]
thresh = cv2.dilate(thresh, None, iterations=2)
cnts, _ = cv2.findContours(thresh.copy(), cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
for c in cnts:
if cv2.contourArea(c) < 12000:
continue
(x, y, w, h) = cv2.boundingRect(c)
cv2.rectangle(frame, (x, y), (x + w, y + h), (0, 255, 0), 2)
cv2.line(frame, (width -15500, 0), (width , 300), (250, 0, 1), 2) #blue line
cv2.line(frame, (width -15500, 0), (width , 400), (0, 0, 255), 2) #red line
rectagleCenterPont = ((x + x + w) /2, (y + y + h) /2)
cv2.circle(frame, rectagleCenterPont, 1, (0, 0, 255), 5)
if(testIntersectionIn((x + x + w) / 2, (y + y + h) / 2)):
textIn += 1
if(testIntersectionOut((x + x + w) / 2, (y + y + h) / 2)):
textOut += 1
# clear the stream in preparation for the next frame
rawCapture.truncate(0)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
cv2.putText(frame, "In: {}".format(str(textIn)), (10, 50),
cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 0, 255), 2)
cv2.putText(frame, "Out: {}".format(str(textOut)), (10, 70),
cv2.putText(frame, datetime.datetime.now().strftime("%A %d %B %Y %I:%M:%S%p"),
(10, frame.shape[0] - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.35, (0, 0, 255), 1)
cv2.imshow("Counter", frame)
Find the line which i commented #This is the part that it has error ... And the error message is
So that is why i tried to use what @6by9 did which was to use sudo modprobe bcm2835-v4l2 to make the pi think that my picam is a USB cam but its just too laggy.. so he suggested to change the width and height.. which i cant i get the errors i mentioned above in my previous post.
