I have a problem with my external HDD connected to Pi3. It is a 2.5" hitachi HDD with 5V 700mA power supply requirement. The only other device plugged in is a keyboard/mouse usb dongle and HDMI. I use the official pi power adaptor. HDD spins and both it and PI have constant power light and keyboard and mouse are working just fine. As PI provides 1.2A on USB ports I assume I have enough power.
I think the HDD is visible in the system and it has been working previously on my laptop, but it is not getting mounted.
Some terminal output:
lsusb
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
[b]Bus 001 Device 007: ID 07ab:0621 Freecom Technologies [/b]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.9 GiB, 15986589696 bytes, 31223808 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00039fa6
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 3275390 3267199 1.6G e W95 FAT16 (LBA)
/dev/mmcblk0p2 3275391 31223807 27948417 13.3G 5 Extended
/dev/mmcblk0p5 3276800 3342333 65534 32M 83 Linux
/dev/mmcblk0p6 3342336 3483647 141312 69M c W95 FAT32 (LBA)
/dev/mmcblk0p7 3489792 31223807 27734016 13.2G 83 Linux
Jan 13 23:00:40 raspberrypi kernel: [ 5831.540382] usb 1-1.3: New USB device found, idVendor=07ab, idProduct=0621
Jan 13 23:00:40 raspberrypi kernel: [ 5831.540396] usb 1-1.3: New USB device strings: Mfr=4, Product=5, SerialNumber=6
Jan 13 23:00:40 raspberrypi kernel: [ 5831.540405] usb 1-1.3: Product: Ext. HDD
Jan 13 23:00:40 raspberrypi kernel: [ 5831.540413] usb 1-1.3: Manufacturer: I
Jan 13 23:00:40 raspberrypi kernel: [ 5831.540421] usb 1-1.3: SerialNumber: 20120816
Jan 13 23:00:40 raspberrypi kernel: [ 5831.541543] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Jan 13 23:00:40 raspberrypi kernel: [ 5831.541931] scsi host0: usb-storage 1-1.3:1.0
Jan 13 23:00:40 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
Jan 13 23:00:40 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
Jan 13 23:00:41 raspberrypi kernel: [ 5832.173240] usb 1-1.3: USB disconnect, device number 6
Jan 13 23:00:49 raspberrypi kernel: [ 5840.397665] usb 1-1.5: reset full-speed USB device number 4 using dwc_otg
Jan 13 23:00:50 raspberrypi kernel: [ 5840.917662] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
Jan 13 23:00:50 raspberrypi kernel: [ 5841.050865] usb 1-1.3: New USB device found, idVendor=07ab, idProduct=0621
Jan 13 23:00:50 raspberrypi kernel: [ 5841.050882] usb 1-1.3: New USB device strings: Mfr=4, Product=5, SerialNumber=6
Jan 13 23:00:50 raspberrypi kernel: [ 5841.050891] usb 1-1.3: Product: Ext. HDD
Jan 13 23:00:50 raspberrypi kernel: [ 5841.050899] usb 1-1.3: Manufacturer: I
Jan 13 23:00:50 raspberrypi kernel: [ 5841.050906] usb 1-1.3: SerialNumber: 20120816
Jan 13 23:00:50 raspberrypi kernel: [ 5841.052055] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Jan 13 23:00:50 raspberrypi kernel: [ 5841.052418] scsi host0: usb-storage 1-1.3:1.0
Jan 13 23:00:50 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
Jan 13 23:00:50 raspberrypi mtp-probe: bus: 1, device: 7 was not an MTP device
Jan 13 23:00:52 raspberrypi kernel: [ 5843.107246] scsi 0:0:0:0: Direct-Access Hitachi HTS547575A9E384 PQ: 0 ANSI: 6
Jan 13 23:00:52 raspberrypi kernel: [ 5843.108814] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
Jan 13 23:00:52 raspberrypi kernel: [ 5843.109390] sd 0:0:0:0: [sda] Write Protect is off
Jan 13 23:00:52 raspberrypi kernel: [ 5843.109406] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
Jan 13 23:00:52 raspberrypi kernel: [ 5843.109685] sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 13 23:00:52 raspberrypi kernel: [ 5843.109990] sd 0:0:0:0: [sda] No Caching mode page found
Jan 13 23:00:52 raspberrypi kernel: [ 5843.110001] sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan 13 23:00:52 raspberrypi kernel: [ 5843.557715] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:53 raspberrypi kernel: [ 5844.127702] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:53 raspberrypi kernel: [ 5844.397739] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:54 raspberrypi kernel: [ 5844.667765] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:54 raspberrypi kernel: [ 5844.937713] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:54 raspberrypi kernel: [ 5845.207763] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:54 raspberrypi kernel: [ 5845.339545] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Jan 13 23:00:54 raspberrypi kernel: [ 5845.339581] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
Jan 13 23:00:54 raspberrypi kernel: [ 5845.339589] blk_update_request: I/O error, dev sda, sector 0
Jan 13 23:00:54 raspberrypi kernel: [ 5845.339599] Buffer I/O error on dev sda, logical block 0, async page read
Jan 13 23:00:54 raspberrypi kernel: [ 5845.437683] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:55 raspberrypi kernel: [ 5845.707675] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:55 raspberrypi kernel: [ 5845.977673] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:55 raspberrypi kernel: [ 5846.247752] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:55 raspberrypi kernel: [ 5846.517717] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:56 raspberrypi kernel: [ 5846.787714] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:56 raspberrypi kernel: [ 5846.919765] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Jan 13 23:00:56 raspberrypi kernel: [ 5846.919816] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
Jan 13 23:00:56 raspberrypi kernel: [ 5846.919831] blk_update_request: I/O error, dev sda, sector 0
Jan 13 23:00:56 raspberrypi kernel: [ 5846.919846] Buffer I/O error on dev sda, logical block 0, async page read
Jan 13 23:00:56 raspberrypi kernel: [ 5847.017762] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:56 raspberrypi kernel: [ 5847.287722] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:56 raspberrypi kernel: [ 5847.557713] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:57 raspberrypi kernel: [ 5847.827728] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:57 raspberrypi kernel: [ 5848.097722] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:57 raspberrypi kernel: [ 5848.367728] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:57 raspberrypi kernel: [ 5848.499482] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Jan 13 23:00:57 raspberrypi kernel: [ 5848.499511] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 00 00 00 08 00
Jan 13 23:00:57 raspberrypi kernel: [ 5848.499519] blk_update_request: I/O error, dev sda, sector 0
Jan 13 23:00:57 raspberrypi kernel: [ 5848.499527] Buffer I/O error on dev sda, logical block 0, async page read
Jan 13 23:00:57 raspberrypi kernel: [ 5848.499896] sda: unable to read partition table
Jan 13 23:00:57 raspberrypi kernel: [ 5848.503487] sd 0:0:0:0: [sda] Attached SCSI disk
Jan 13 23:00:58 raspberrypi kernel: [ 5848.917746] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:58 raspberrypi kernel: [ 5849.447760] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:59 raspberrypi kernel: [ 5849.717735] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:59 raspberrypi kernel: [ 5849.987739] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:59 raspberrypi kernel: [ 5850.257743] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:00:59 raspberrypi kernel: [ 5850.527765] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:00 raspberrypi kernel: [ 5850.659737] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Jan 13 23:01:00 raspberrypi kernel: [ 5850.659787] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 57 54 66 00 00 00 08 00
Jan 13 23:01:00 raspberrypi kernel: [ 5850.659806] blk_update_request: I/O error, dev sda, sector 1465148928
Jan 13 23:01:00 raspberrypi kernel: [ 5850.757817] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:00 raspberrypi kernel: [ 5851.027768] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:00 raspberrypi kernel: [ 5851.297772] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:00 raspberrypi kernel: [ 5851.567753] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:01 raspberrypi kernel: [ 5851.837752] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:01 raspberrypi kernel: [ 5852.107819] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
Jan 13 23:01:01 raspberrypi kernel: [ 5852.239760] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
Jan 13 23:01:01 raspberrypi kernel: [ 5852.239811] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 57 54 66 00 00 00 08 00
Jan 13 23:01:01 raspberrypi kernel: [ 5852.239830] blk_update_request: I/O error, dev sda, sector 1465148928
Jan 13 23:01:01 raspberrypi kernel: [ 5852.239847] Buffer I/O error on dev sda, logical block 183143616, async page read
Thank you.
