I'm planning on making a Nintendo switch clone with a raspberry pi 3.
I found this on the forum but it's for raspberry zero. I assume that the connection to the raspberry is different but is the rest good for the rasp 3 ?
https://i.imgur.com/74mlicv.png
Also, I found a lot of stuff. Can you tell me if that's good?
- a simple little on/off switch
- the adafruit powerboost 1000c
- this sound card + jack to disassemble a little
- 2 gameboy color/advance speakers (idk
- a gameboy color volume wheel
- this micro USB charging port
- this USB hub to disassemble (I was told it work on raspberry zero)
- This stereo amp
- this controller who I want to disasemble to connect it with cables to the raspberry
- this screen
- this controller board for the screen
- a battery (I'll take according to the place I have left)
- a box printed with a 3D printer
I'm not sure at all for the screen and the controller board if they gonna work with the rasp....
Also, I wonder if I Can use two different controllers to play without redoing the keys each time. The one I said above for portable mode and an ajouter bluetooth one for TV mode.
What do you think ?
