mvdvarrier
PiServer - Client OS installing error using apt
Sat Jan 13, 2018 2:07 pm
I have installed Raspbian for PC in a desktop computer. after installation when I tried to configure pi clients through PiServer;
The MAC address of the client pi3 has been detected but when i tried to install the client OS (Raspbian regular or lite) in the next step, the installation quits by showing following error message "Error executing 'apt-get -q -y install dnsmasq openssh-server nfs-kernel-server slapd libnss-ldapd libpam-ldapd ldap-utils gnutls-bin'
Help in this matter will be highly appreciated.
mikerr
Re: PiServer - Client OS installing error using apt
Sat Jan 13, 2018 2:25 pm
The PC running PiServer needs internet access - at least for first setup.
Try typing that command in the terminal:
sudo apt-get -q -y install dnsmasq openssh-server nfs-kernel-server slapd libnss-ldapd libpam-ldapd ldap-utils gnutls-bin
mvdvarrier
Sat Jan 13, 2018 2:31 pm
The internet connection is OK, That I am writing this post from the PC
mvdvarrier
Sat Jan 13, 2018 2:34 pm
Qustion: "There is no Raspbian for x86 machines, did you actually install Debian Stretch with Raspberry Pi Desktop ??"
Oh Sorry! Precisely My OS running in the PC is Linux raspberry 4.9.0-4-amd64 #1 SMP Debian 4.9.51-1 (2017-09-28) x86_64 GNU/Linux
mvdvarrier
Sat Jan 13, 2018 2:52 pm
When tried the command the error is as follows;
Reading package lists...
Building dependency tree...
Reading state information...
Package nfs-kernel-server is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
nfs-common
Package slapd is not available, but is referred to by another package.
Package ldap-utils is not available, but is referred to by another package.
E: Package 'nfs-kernel-server' has no installation candidate
E: Package 'slapd' has no installation candidate
E: Unable to locate package libnss-ldapd
E: Unable to locate package libpam-ldapd
E: Package 'ldap-utils' has no installation candidate
Sat Jan 13, 2018 3:16 pm
nfs-common
In Debian Stretch they are all valid packages, did you run:
sudo apt update
sudo apt dist-upgrade
https://packages.debian.org/stretch/nfs-common
https://packages.debian.org/stretch/ldap-utils
https://packages.debian.org/stretch/libnss-ldapd
https://packages.debian.org/stretch/slapd
https://packages.debian.org/stretch/libpam-ldapd
Adieu
Sat Jan 13, 2018 4:45 pm
Still not full information, cat /etc/os-release, see:
https://linuxconfig.org/check-what-debi ... nux-system
Adieu
mvdvarrier
Sun Jan 14, 2018 2:14 am
sudo apt update
Even after the distro upgrading the apt, same error repeats.
mvdvarrier
Sun Jan 14, 2018 2:37 am
I think the problem is now solved .
I just carefully inspected the entries in the /etc/apt/sources.list file.
the default entries are
deb http://security.debian.org/debian-security stretch/updates main
deb-src http://security.debian.org/debian-security stretch/updates main
I just added the line
deb http://httpredir.debian.org/debian/ stretch main contrib non-free
I think the non-free item can be avoided but i have an old nvidia card and i need it.
This line solved all the issues during updating and OS installation by the PiServer.
I suspect this error with sources.list file caused by any startup scripts during installation.
Any how thanks to all who helped me with my humble problem. Thanks gentlemen, Thanks!!!
mikerr
Sun Jan 14, 2018 10:16 am
Glad you got it sorted, but for clarity my default unaltered sources.list reads like this:
deb http://ftp.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
# Uncomment lines below then 'apt-get update' to enable 'apt-get source'
#deb-src http://ftp.debian.org/debian/ stretch main contrib non-free
#deb-src http://security.debian.org/ stretch/updates main contrib non-free
#deb-src http://ftp.debian.org/debian/ stretch-updates main contrib non-free
Return to “Raspberry Pi Desktop for PC and Mac”
Who is online
Users browsing this forum: PiYeoman and 0 guests
