Im_Int
How to disable HDMI in the absence of user input during boot-up?
Sat Jan 13, 2018 5:19 am
I have a bash script that asks the user whether to keep HDMI on, and if no key is pressed within 10 seconds, HDMI is turned off. Unfortunately, calling this script from /etc/rc.local doesn't work — there's no prompt, and HDMI always ends up switched off. If I call the script manually from CLI, everything works as it should.
#!/bin/bash
if read -n1 -s -r -t10 -p $'Press any key to keep HDMI on\n' KEY
then
    echo "HDMI will remain on"
else
    /usr/bin/tvservice -o
fi
klricks
Re: How to disable HDMI in the absence of user input during boot-up?
Sun Jan 14, 2018 2:44 am
If you are booting to GUI then using autostart is easier. Here is a recent thread with info on how to:viewtopic.php?f=63&t=199672#p1258334
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
Sun Jan 14, 2018 9:52 am
If you pull the HDMI cable then your Raspberry will automatically disable any HDMI function (unless you force HDMI use in /boot/config.txt).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Im_Int
Tue Jan 16, 2018 1:03 am
I have all HDMI lines commented off in /boot/config.txt (it's a mint installation of raspbian) but /usr/bin/tvservice -o shaves off 20 mA even with the HDMI cable not plugged in
Return to “Raspbian”
Who is online
Users browsing this forum: Bing [Bot], cjan, w4mmp and 18 guests
