Attribute error in python 3
Sat Jan 13, 2018 12:08 am
Hi, I'm a beginner and I am trying to run this program on my raspberry pi 2 model b, with python3 for a school project.
I am really frustrated because I'm blocked because I can't find the solution to this ''Atribute error''
I updated my raspberry to the latest version by the way.
Here is my code
import wiringpi as wp
import RPi.GPIO as GPIO
import time
PIN = 18   #5
PWMA1 = 6   #gnd
PWMA2 = 13  #2
PWMB1 = 20  #gnd
PWMB2 = 21  #miso
D1 = 12     #1
D2 = 26     #ce1
ECHO = 4
TRIG = 14
PWM = 25
p1 = GPIO.PWM(D1,500)
p2 = GPIO.PWM(D2,500)
def set_motor(A1,A2,B1,B2):
        print ("setting motors...")
def forward():
	print ("going forward")
def stop():
	print ("stop")
def reverse():
	print ("reverse")
def left():
	print ("left")
def right():
	print ("right")
print ("Distance measurement in progress")
GPIO.setup(TRIG,GPIO.OUT)                  #Set pin as GPIO out
GPIO.setup(ECHO,GPIO.IN)                   #Set pin as GPIO in
class MrBit_QTR_8RC:
    """ Class for reading values from Pololu QT8-8RC sensor array.
        Requires wiringpi
def __init__(self):
        """ Initialises class constants and variables - pins defined here.
        self.wp = wp
        self.LEDON_PIN = 21
        self.SENSOR_PINS = [10, 3]
        self.NUM_SENSORS = len(self.SENSOR_PINS)
        self.CHARGE_TIME = 10 #us to charge the capacitors
        self.READING_TIMEOUT = 1000 #us, assume reading is black
        self.sensorValues = []
        self.calibratedMax = []
        self.calibratedMin = []
        self.lastValue = 0
def init_pins(self):
        """ Sets up the GPIO pins and also ensures the correct number of items
            in sensors values and calibration lists to store readings.
        for pin in self.SENSOR_PINS:
            self.wp.pullUpDnControl(pin, self.wp.PUD_DOWN)
        self.wp.pinMode(self.LEDON_PIN, self.wp.OUTPUT)
def emitters_on(self):
        """ Turns the LEDON pin on so that the IR LEDs can be turned on.
            If there is nothing wired to LEDON emitters will always be on.
            Use emitters_on and emitters_off to conserve power consumption.
        self.wp.digitalWrite(self.LEDON_PIN, self.wp.HIGH)
def emitters_off(self):
        """ Turns the LEDON pin off so that the IR LEDs can be turned off.
        self.wp.digitalWrite(self.LEDON_PIN, self.wp.LOW)
def print_sensor_values(self, values):
        """ Params: values - a list of sensor values to print
            Prints out the sensor and it's current recorded reading.
        for i in range(0, self.NUM_SENSORS):
            print("sensor %d, reading %d" % (i, values[i]))
def initialise_calibration(self):
        """ Resets (inverse) max and min thresholds prior to calibration
            so that calibration readings can be correctly stored.
            self.calibratedMax[i] = 0
            self.calibratedMin[i] = self.READING_TIMEOUT
def calibrate_sensors(self):
        """ Takes readings across all sensors and sets max and min readings
            typical use of this function is to call several times with delay
            such that a total of x seconds pass.  (e.g. 100 calls, with 20ms
            delays = 2 seconds for calibration).  When running this move the
            sensor over the line several times to calbriate contrasting surface.
        for j in range(0, 10):
                if self.calibratedMax[i] < self.sensorValues[i]:
                    self.calibratedMax[i] = self.sensorValues[i]
                if self.calibratedMin[i] > self.sensorValues[i] and self.sensorValues[i] > 30:
                    self.calibratedMin[i] = self.sensorValues[i]
def read_line(self):
        """ Reads all calibrated sensors and returns a value representing a
            position on a line.  The values range from 0 - 7000, values == 0 and
            values == 7000 mean sensors are not on line and may have left the
            line from the right or left respectively.  Values between 0 - 7000
            refer to the position of sensor, 3500 referring to centre, lower val
            to the right and higher to the left (if following pin set up in init).
        avg = 0
        summ = 0
        online = False
            val = self.sensorValues[i]
            if val > 500: online = True
            if val > 50:
                multiplier = i * 1000
                avg += val * multiplier
                summ +=  val
        if online == False:
            if self.lastValue < (self.NUM_SENSORS-1)*1000/2:
                return 0
                return (self.NUM_SENSORS-1)*1000
        self.lastValue = avg/summ
        return self.lastValue
def read_calibrated(self):
        """ Reads the calibrated values for each sensor.
        print("uncalibrated readings")
            denominator = self.calibratedMax[i] - self.calibratedMin[i]
            val = 0
            if denominator != 0:
                val = (self.sensorValues[i] - self.calibratedMin[i]) * 1000 / denominator
            if val < 0:
                val = 0
            elif val > 1000:
                val = 1000
            self.sensorValues[i] = val
        print("calibrated readings")
def read_sensors(self):
        """ Follows the Pololu guidance for reading capacitor discharge/sensors:
            1. Set the I/O line to an output and drive it high.
            2. Allow at least 10 us for the sensor output to rise.
            3. Make the I/O line an input (high impedance).
            4. Measure the time for the voltage to decay by waiting for the I/O
                line to go low.
            Stores values in sensor values list, higher vals = darker surfaces.
            self.sensorValues[i] = self.READING_TIMEOUT
        for sensorPin in self.SENSOR_PINS:
            self.wp.pinMode(sensorPin, self.wp.OUTPUT)
            self.wp.digitalWrite(sensorPin, self.wp.HIGH)
            self.wp.pinMode(sensorPin, self.wp.INPUT)
            #important: ensure pins are pulled down
            self.wp.digitalWrite(sensorPin, self.wp.LOW)
        startTime = self.wp.micros()
        while self.wp.micros() - startTime < self.READING_TIMEOUT:
            time = self.wp.micros() - startTime
                if self.wp.digitalRead(self.SENSOR_PINS[i]) == 0 and time < self.sensorValues[i]:
                    self.sensorValues[i] = time
#Example ussage:
if __name__ == "__main__":
        qtr = MrBit_QTR_8RC()
        approveCal = False
        while not approveCal:
                for i in range(0, 250):
                        print ("calibration complete")
                        print ("max vals")
                        print ("min vals")
                        approved = raw_input("happy with calibrtion (Y/n)? ")
                        if approved == ("Y"): approveCal = True
        while True:
            GPIO.output(TRIG, False)                 #Set TRIG as LOW
            print ("Waitng For Sensor To Settle")
            time.sleep(2)                            #Delay of 2 seconds
            GPIO.output(TRIG, True)                  #Set TRIG as HIGH
            time.sleep(0.00001)                      #Delay of 0.00001 seconds
            while GPIO.input(ECHO)==0:               #Check whether the ECHO is LOW
                pulse_start = time.time()              #Saves the last known time of LOW pulse
            while GPIO.input(ECHO)==1:               #Check whether the ECHO is HIGH
                pulse_end = time.time()                #Saves the last known time of HIGH pulse
            pulse_duration = pulse_end - pulse_start #Get pulse duration to a variable
            distance = pulse_duration * 17150        #Multiply pulse duration by 17150 to get distance
            distance = round(distance, 2)            #Round to two decimal points
            if distance < 30:
                print ("Collision imminente")
                print ("Distance:",distance - 0.5,"cm")
            if qtr.sensorValue[1] > 350:
                print ("going right")
            if qtr.sensorValue[0] > 350:
                print ("going left")
    except Exception as e:
            print (e)
        while 1:
            print (qtr.read_line())
    except KeyboardInterrupt:
        print (e)
And here is the error message I'm getting
  File "/home/pi/Desktop/Python/line following robot", line 252, in <module>
AttributeError: 'MrBit_QTR_8RC' object has no attribute 'initialise_calibration'
During handling of the above exception, another exception occurred:
  File "/home/pi/Desktop/Python/line following robot", line 304, in <module>
AttributeError: 'MrBit_QTR_8RC' object has no attribute 'emitters_off'
It would be cool if someone helped me with this because I'm not expererienced enough to solve that problem...
Best regards,
Re: Attribute error in python 3
Sat Jan 13, 2018 1:35 am
Where did you get the code from?
After the "class MrBit_QTR_8RC:" line, each of the next ten "def method(self…):" lines should have been indented four characters so that they belong to the class. (The bodies of those definitions are already indented eight characters to make room.)
Because your definitions are back in the first column, they belong to the main program, and class MrBit_QTR_8RC has no method attributes.
I also wonder whether it was really intended that the class be pasted into the middle of the script and then used in the same file. Usually the benefit comes when you put a class into a module file, such as, and then you can use it in multiple programs with "from mrbit import MrBit_QTR_8RC".
Sat Jan 13, 2018 1:37 am
Your class MrBit_QTR_8RC doesn't appear to have anything in it other than the docstring. By the looks of it all those functions below it belong in the class but since you unindented all the def ... lines they aren't. Python relies on indentation to say what is within each block.
She who travels light — forgot something.
Sat Jan 13, 2018 2:58 am
First, thank you very much Paeryn and jojopi for your replies!
I'll try to correct the indentation as soon as possible and I'll tell you back about it.
Jojopi, this code is for a line following robot with a HC-SR04 sensor and a QTR-8RC Reflectance Sensor Array ( which is a module with 8 IR led paired with phototransistors (I am only using two of the IRled/phototransistors pairs).
To answer your question, I get the reflectance sensor array code from : ... -wiringpi/
Finally, you proposed me to put the class into a module file, but I have no idea how to do that.
I did not create the class by myself...
Maybe I should ask the guy who made it...
Best regards,
Sat Jan 13, 2018 8:56 pm
I corrected the indentation and it works!
Thanks for your help!
Return to “Python”
Who is online
Users browsing this forum: No registered users and 19 guests
