beatsal
GPS module in Python
Fri Jan 12, 2018 1:07 am
From another post, I tried the following line to import the gps module into a python script but get error 'no module named gps'
sudo apt-get install python{,3}-rpi.gps (this line in PI terminal)
I then used the foll. line in python script:
from gps import *
Eliter
Re: GPS module in Python
Fri Jan 12, 2018 5:06 am
I do not code in Python, but I do believe apt-get packages generally do not contain the characters: "{", "}", ",", or ".".
For future advice, I recommend helping us help you better by providing more information on your post next time, because it is unclear what you want.
The command looks like you are trying to install the Python package. My guess on installing Python is the command: "sudo apt-get install python". What I am guessing is that you are confusing the concept of being able to use/interact with programming stuff from another library/file. My recommendation is to figure out how to do that in your code, NOT in the command line. Some typical keywords I recommend you lookup in your Python language book (or you can find one--probably free online) are: "include", "require", "import", "uses", or "inherit".
Fri Jan 12, 2018 11:24 am
That's bash syntax to install both the python2 and python3 versions python-rpi.gps & python3-rpi.gps with a single command.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
dgordon42
Fri Jan 12, 2018 12:07 pm
Try running:
sudo apt install python-gps
I don't see a Python3 version in the Raspbian repositories, so you will have to just use Python 2.
Hope this helps,
Dave.
scotty101
Fri Jan 12, 2018 12:10 pm
There is a gps3 module that works for both Python2 and Python3
https://pypi.python.org/pypi/gps3/
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
beatsal
Fri Jan 12, 2018 8:33 pm
Thanks. Tried the foll. script and used python 2 as it just would not accept py 3 although I tried with the bash command that Dougie mentioned. Now no error but for some reason, it does not write to the file locations.csv although it does open the file.
from gps import *
import time
import threading
f = open("locations.csv","w")
gpsd = None
class GpsPoller(threading.Thread):
   def __init__(self):
       threading.Thread.__init__(self)
       global gpsd
       gpsd=gps(mode=WATCH_ENABLE)
       self.current_value = None
       self.running = True
   def run(self):
       global gpsd
       while gpsp.running:
           gpsd.next()
if  __name__ == "__main__":
   gpsp=GpsPoller()
   try:
       gpsp.start()
       while True:
           f.write(str(gpsd.fix.longitude) + "," + str(gpsd.fix.latitude) + "\n")
           time.sleep(30)
   except(KeyboardInterrupt,SystemExit):
       f.close()
       gpsp.running = False
       gpsp.join()
saltydog
Fri Jan 12, 2018 11:24 pm
Try:
from gps import *
import time
import threading
gpsd = None
   def __init__(self):
       global gpsd
       self.running = True
   def run(self):
       global gpsd
       while gpsp.running:
           gpsd.next()
   gpsp=GpsPoller()
   try:
       gpsp.start()
       while True:
           with open("locations.csv","w") as f:
           time.sleep(30)
       gpsp.join()
Chris
beatsal
Sat Jan 13, 2018 3:05 pm
Thanks Chris.
No error but it only writes "0.0,0.0" to locations.csv
B.Goode
Sat Jan 13, 2018 3:36 pm
Thanks Chris.
Have you checked that the GPS receiver is in a location where it has an unobstructed view of the sky in most directions, and that the receiver has actually established a 'fix' on no less than 4 'visible' GPS satellites?
There are other client tools that are available to interrogate a gpsd server, to check that it is operating correctly in conjunction with your GPS receiver.
bensimmo
Stick a print statement in before the writes and see what it's saying (or debug in Thonny if it now copes with threads).
Also use print in other places to see what is happening.
It might not be seeing a lock yet and hence no location. That or you're on a boat in the Gulf of Guinea (iirc?)
beatsal
Sat Jan 13, 2018 10:08 pm
Thanks. I do get the gps values (lat, lon) updating every second - I used:
gpsmon /dev/serial0 and it works fine
I used the script sent few hours ago by Chris verbatim. Still no luck; considering I am not in Guinea but freezing in Canada, just can't fathom what's going wrong!
beatsal
Sat Jan 13, 2018 10:27 pm
I tried the suggestion to add a print statement before the write. No change in file locations.csv i.e. it prints 0.0 0.0,0.0 0.0 as before, but now it prints 0.0 every 30 secs in the python shell.
Wonder if the gps data is written too fast i.e. every second, hence locations.py cannot keep up?
bensimmo
Sat Jan 13, 2018 10:34 pm
gpsmon shows it working :-)
But it uses its own code to get gps from it.
is gpsd setup and working? does it know shic serial location it can get info from (use cgps or xgps as they use gpsd)
the print shows what would be written, so the 'save' isn't a problem.
No idea how your code is suppose to work as I don't know that gps module.
beatsal
Sat Jan 13, 2018 11:04 pm
tried cgps and got a static table (no updates). similar with xgps, so may be they don't work? this is a popular gps module from Adafruit PA6H
Sat Jan 13, 2018 11:41 pm
Does your GPS device appear as a TTY device? Take a look with a ls -la /dev/ttyS* /dev/ttyA* command.
What do you get if you run gpsd -D 2 -N so that you get lots of debug info?
MQTT Evangelist
beatsal
Sun Jan 14, 2018 12:36 am
Keyed in the first, got:
ctw-rw -1 /dev/ttyAMA0
ctw-rw -1 /dev/ttyS0
2nd cmd i.e. gpsd-D 2 -N :
gpsd: ERROR: can't run with control socket or devices
bensimmo
Sun Jan 14, 2018 9:01 am
Did you set gpsd up?
Because something is wrong with the setup.
Serial is working and the module is working (gpsmon, it doesn't use gpsd but it own internal 'drivers') but is show you that it is all working.
gpsd is the go between program your code is using.
First
sudo killall gpsd
These are the normal steps that are used to install and setup from scratch.
sudo apt-get install gpsd gpsd-clients python-gps
sudo systemctl stop gpsd.socket
sudo systemctl disable gpsd.socket
sudo gpsd /dev/serial0 -F /var/run/gpsd.sock
Wait and run cgps -s or xgps (xgps is only work in the desktop)
If you ever get in a mess then to reset gpsd
sudo killall gpsd
(Often if you've not left it till it gets a lock for cgps)
You need to run this everything you reboot, normally before you run the program (could do it in code, I used to do it in rc.local)
You can setup the config file to do it automatically at boot, and re-enable the services we stopped, iirc, but I forget where I put the setup notes for that.
It's been a while since I've done it and that was under Jessie.
Hope that helps.
Sun Jan 14, 2018 11:51 am
I've just wired my ancient Garmin eTrex GPS to my RPiZ. It sends NMEA at 4800,8,N,1.
It appeared as /dev/ttyUSB0 so I can read that with
#!/usr/bin/python3
import serial
while True:
  with serial.Serial('/dev/ttyUSB0', 4800, timeout=1) as ser:
    line = ser.readline()
    print (line)
If I set up gpsd with /etc/default/gpsd
# Default settings for the gpsd init script and the hotplug wrapper.
# Start the gpsd daemon automatically at boot time
START_DAEMON="true"
# Use USB hotplugging to add new USB devices automatically to the daemon
USBAUTO="true"
# Devices gpsd should collect to at boot time.
# They need to be read/writeable, either by user gpsd or the group dialout.
DEVICES="/dev/ttyUSB0"
# Other options you want to pass to gpsd
GPSD_OPTIONS="-D 3"
for lots of debugging info.
I can use telnet localhost 2947 then enter ?WATCH={"enable":true, "json":true, "nmea": true}[ENTER]
Trying ::1...
Connected to localhost.
Escape character is '^]'.
{"class":"VERSION","release":"3.16","rev":"3.16-4","proto_major":3,"proto_minor":11}
{"class":"DEVICES","devices":[{"class":"DEVICE","path":"/dev/ttyUSB0","driver":"NMEA0183","activated":"2018-01-14T11:43:12.840Z","flags":1,"native":0,"bps":4800,"parity":"N","stopbits":1,"cycle":1.00}]}
{"class":"WATCH","enable":true,"json":true,"nmea":true,"raw":0,"scaled":false,"timing":false,"split24":false,"pps":false}
$GPRMB,A,,,,,,,,,,,,A,A*0B
$GPGGA,113310,5114.????,N,00108.????,W,1,05,2.5,121.3,M,48.3,M,,*5F
{"class":"TPV","device":"/dev/ttyUSB0","mode":3,"time":"2018-01-14T11:33:10.000Z","ept":0.005,"lat":51.2?????,"lon":-1.13????,"alt":121.300,"epx":26.965,"epy":22.776,"epv":85.100,"speed":0.000,"climb":-0.050,"eps":20.97,"epc":61.34}
$GPGSA,A,3,02,05,06,07,,13,,,,,,,4.5,2.5,3.8*3B
$GPGSV,3,3,11,23,08,078,00,29,07,307,00,30,56,165,00*45
{"class":"SKY","device":"/dev/ttyUSB0","xdop":1.80,"ydop":1.52,"vdop":3.80,"tdop":2.93,"hdop":2.50,"gdop":4.99,"pdop":4.50,"satellites":[{"PRN":2,"el":42,"az":242,"ss":44,"used":true},{"PRN":5,"el":46,"az":298,"ss":40,"used":true},{"PRN":6,"el":26,"az":200,"ss":40,"used":true},{"PRN":7,"el":64,"az":117,"ss":34,"used":true},{"PRN":9,"el":45,"az":74,"ss":0,"used":false},{"PRN":13,"el":11,"az":252,"ss":40,"used":true},{"PRN":16,"el":13,"az":31,"ss":0,"used":false},{"PRN":23,"el":12,"az":76,"ss":0,"used":false},{"PRN":29,"el":9,"az":311,"ss":0,"used":false},{"PRN":30,"el":52,"az":168,"ss":0,"used":false},{"PRN":23,"el":8,"az":78,"ss":0,"used":false},{"PRN":29,"el":7,"az":307,"ss":0,"used":false},{"PRN":30,"el":56,"az":165,"ss":0,"used":false}]}
$GPGLL,5114.????,N,00108.????,W,114312,A,A*5C
^C^]
telnet> quit
Connection closed.
And I can read that data with gps-py3
#!/usr/bin/python3
import gpsd
gpsd.connect()
print (gpsd.device())
while True:
  print (gpsd.get_current())
Note: I've redacted my co-ordinates in the NMEA sentences.
MQTT Evangelist
