Thu Oct 18, 2012 12:50 pm
Without meaning to cause offence, you are misguided in believing that electronic goods bought from an online shop are of better quality, or even different to those sold on eBay.
The fact is that (almost) all of these products are made in China by small manufacturers who buy components and sub-assemblies from China's industrial infrastructure. Yes, there are a lot of fakes out there but the sad reality is that many of the branded goods are made in the same premises as the fakes.
As has been said elsewhere, the best way to power a Rev 2 (or late Rev 1) RPi is by backfeeding one of the USB Ports from a Hub. This obviates three of the problems inherent in feeding the MicroUSB Socket:
a) Most MicroUSB Chargers being intended for Mobile Phones are rated at 1 Amp or less.
b) The MicroUSB Connector and the cables used are too flimsy to carry the current required without excessive Voltahe drop.
c) There is a 1 Amp PolyFuse on the RPi Board, just inboard of the MicroUSB Socket and this component is known to cause an excessive volt drop, especially if subjected to repeated stress near to its rated limit.
The answer is to use a POWERED Hub which usually comes with a short but robust cable to the RPi. unfortunately, most of these Hubs are suppied with inadequate Power Supplies but because they ise the standard 5.5mm/ 2.1mm barrel connector, you can use a standard PSU rated at 5V, 2A REGULATED.
I hope this helps.
