serverius
Code for displaying an image (raspberry pi 3 & Python)
Tue Jan 09, 2018 9:39 pm
Hello Everybody,
I have a question that i hope somebody can help me with.
At work (i work as a designer and IT Manager for a company who designs and installs indoor playgrounds) we are trying work out an idea we have regarding a new play item to use in our playgrounds.
The idea was to create a kind of interactive traffic circuit combined with images that we are going to project using beamers, sound and some IO stuff for infrared etc.
Now the IO part is working but i have a problem with the code i should use regarding the images.
When i use the terminal with feh i have no problem to display the images fullscreen, but this does not seem to work very well from within python (or i am doing something wrong, kind of a python novice to be honest, but working on it :-) )
From the terminal, i use the following command :
feh --hide-pointer -x -q -B black -g 1280x800 /path/to/image/pic.jpg
This works perfect from within the terminal but not from within python.
Could somebody help me out, what i need it that the image is displayed fullscreen (1280x800) for a numer of seconds and at the same time it should also play the sound. Now for the sound part, i did not go into that part deeper so maybe this will be easy but i am completely stuck, so i hope somebody could help me out with some code i can put into the rest of my code.
And any tips regarding the sound code would also help me out immensely. the idea is that it keeps playing/repeating a specific mp3 file for a specific number of seconds.
Hope somebody could help me out,
Thanks a lot for any input.
Best Regards,
serverius
davef21370
Re: Code for displaying an image (raspberry pi 3 & Python)
Wed Jan 10, 2018 6:45 pm
Check out PyGame, it does all that stuff & loads of online examples.
Dave.
Apple say... Monkey do !!
OutoftheBOTS
Fri Jan 12, 2018 11:35 am
The PIL (Python Imaging Library) library is the main python graphic library see http://effbot.org/imagingbook/
serverius
Fri Jan 12, 2018 2:57 pm
Dave.
Thanks for the info.
I had a look at the pygame but could not get that to work like i needed.
import pygame #voor beeld en geluid
from time import sleep
from pygame.locals import *
pygame.init()
WIDTH = 1280
HEIGHT = 800
windowSurface = pygame.display.set_mode((WIDTH, HEIGHT), 0, 0)
img = pygame.image.load("/home/pi/images/pic06.jpg")
windowSurface.blit(img, (0, 0))
pygame.display.flip()
# sound code
pygame.mixer.init()
pygame.mixer.music.load("/home/pi/sound/dog.mp3")
pygame.mixer.music.play()
while pygame.mixer.music.get_busy() == True:
    continue
I used this code, but the problem i encountered was that there was a delay between the time the screen appears and the actual displaying of the image.
I would need it to display a certain image fullscreen at 1280x800 without borders and for a certain amount of seconds.
I found another solution for the images with the following code :
import RPi.GPIO as GPIO
import os
os.system ('feh --hide-pointer -x -q -B black -g 1280x800 "/home/pi/images/pic01.jpg" &')
The only problem i have is that the images do not dissapear, i use a total of 12 images in the whole code and when it is finished i need to press escape 12 times because this just stacks the image screens on top of each other.
Any ideas on how to close the images with the feh command ?
And if anybody knows what pygame code i need to use to get the same results as with the feh command, that would really help me out.
Thanks,
serverius
Fri Jan 12, 2018 2:58 pm
Thanks for the advice, i'll have a look at that.
Thanks,
elParaguayo
Fri Jan 12, 2018 7:16 pm
You could use the subprocess module rather than os.system.
As an example:
import subprocess
#Display the image
image = subprocess.Popen(["feh", "--hide-pointer", "-x", "-q", "-B", "black", "-g", "1280x800", "/home/pi/images/pic01.jpg"])
# Do other stuff here...
# You can now close the image by doing
image.kill()
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
serverius
Fri Jan 12, 2018 10:09 pm
You have saved my life!!!!!
Works perfect, thanks ever so much
As an example:
import subprocess
#Display the image
image.kill()
elParaguayo
Sat Jan 13, 2018 7:22 am
Well, I wouldn't go that far but I'm glad I could help!
Return to “Python”
Who is online
Users browsing this forum: No registered users and 10 guests
