Stogy
Wifi not working on Pi Zero W [solved]
Sun Jan 07, 2018 9:20 pm
So I recently got the Raspberry Pi Zero W and tried to setup the wifi. Don’t have a cable for monitor/usb so decided to try headless.
Created the file ssh and wpa_supplicant.conf
network={
    ssid="Wifi name"
    psk="Password"
    key_mgmt=WPA-PSK
However it doesn’t show up in my router list, so I cannot ssh into it. When I check the SD the files ssh and wpa_supplicant.conf are gone, and according to the documentation that should happen. So I would have thought it would work.
Also tried PiBakery to set it up but that doesn’t make it connect either. Anybody knows why ?
pcmanbob
Re: Wifi not working on Pi Zero W
Sun Jan 07, 2018 11:30 pm
Your wpa_supplicant.conf needs to contain this.
update_config=1
country=GB
network={
    ssid="Wifi name"
    psk="Password"
    key_mgmt=WPA-PSK
you may need to change the country code from GB to one matching your location.
Stogy
Mon Jan 08, 2018 12:26 am
update_config=1
country=GB
network={
    ssid="Wifi name"
    psk="Password"
    key_mgmt=WPA-PSK
Tried this but it’s still not working
pcmanbob
Mon Jan 08, 2018 9:40 am
Did you make any other changes yourself or using PiBakery ?
mattmiller
Mon Jan 08, 2018 11:50 am
Trying to get a PiZeroW working on WiFi is a real chicken/egg scenario as you really have to KNOW that your wpa_supplicant.conf file is valid
One little missing " or 1 char mistake in the SSID or password and it won't work.
Get the file right and your 99.9999% guaranteed sucess
Note: The PiZero (and Pi3) built in antenna is a bit small compared to a WiFi dongle so you may find that it has to be a bit closer than other devices to your router
And as always, if any device is having trouble connecting to a router - switch the router off and on :)
Stogy
Mon Jan 08, 2018 12:27 pm
Apparently the country setting was the fault here. I removed th country line and it works fine now.
I’m from the Netherlands so i added country=NL but that didn’t work nor did any other country. Not sure why.
mattmiller
Mon Jan 08, 2018 12:37 pm
Interesting - as an experiment (in case was an issue when file being edited before sticking into your Pi)
Can you now edit it on your working Pi
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
and stick the country line back in and see what happens when you reboot?
Stogy
Mon Jan 08, 2018 5:40 pm
I tried PiBakery but that didn’t work at all for me.
mattmiller wrote: Interesting - as an experiment (in case was an issue when file being edited before sticking into your Pi)
If I put the country line back in it crashes the Wifi again and won’t connect. Which is weird, but I found my fix I guess.
PiBakery
Wed Jan 10, 2018 1:32 am
Interesting, so just to clarify it was adding the two lines
update_config=1
that made it work?
If that's the case I'll add it to the next update of PiBakery.
PiBakery - The easiest way to setup a Raspberry Pi
www.PiBakery.org
@PiBakery
dad2four
Tue Jan 16, 2018 11:27 pm
Just to add my .02. I'm a total failure as well. Went back for a second pi to be sure the first wasn't bad. Still can't get headless to work. I'm using the hotspot on my phone to be sure I can see the device if it connects. No love. I even went with Jessie lite to be sure this wasn't a stretch problem. I'm using a 1.1 zero if it makes a difference.
mattmiller
Re: Wifi not working on Pi Zero W [solved]
Wed Jan 17, 2018 7:17 am
To try and sort it out - can you take the password off your phone hotpsot and then us know what SSID you've set it to (the real actual one)
(If you actual password is something like 0123456789 then don't bother removing it - just tell us what it is :)
We can then make a working wpa_supplicant file for you and eliminate that as source of the problem
dad2four
Thu Jan 18, 2018 8:23 pm
The issue I was having was that I run a VPN on my phone. I turned the VPN off and everything was fine.
karon
Tue Feb 13, 2018 8:08 pm
Same issue with pi zero w and pibakery
added these lines to wifi py script (forgot his name) :
update_config=1
country=FR
and it works fine :)
thanks for pibakery, great idea !
RisiJay
Sat Oct 24, 2020 7:52 am
Have the same problem. Wifi wont connect and crashed. thanks for the fix!
