resipete
Problem with Snake game design
Sat Jan 06, 2018 8:51 pm
Hi there,
I have recently got a raspberry pi and am looking at a beginners guide. In it I'm on a chapter about programming in python and specifically creating the game snake using python. In it, it provides written code that can be used to design the game however when I run the code the game runs ok, apart from the problem that the snake doesn't constantly move. It only moves when a key is pressed. I can see in the code that this is the case but I am not sure how I would rectify this so any help anyone could give me would be great. I will paste the code I used also
#!/usr/bin/env python
import pygame, sys, time, random
from pygame.locals import *
pygame.init()
fpsClock = pygame.time.Clock()
playSurface = pygame.display.set_mode((640, 480))
pygame.display.set_caption('Raspberry Snake')
redColour = pygame.Color(255, 0, 0)
blackColour = pygame.Color(0, 0, 0)
whiteColour = pygame.Color(255, 255, 255)
greyColour = pygame.Color(150, 150, 150)
snakePosition = [100,100]
snakeSegments = [[100,100],[80,100],[60,100]]
raspberryPosition = [300,300]
raspberrySpawned = 1
direction = 'right'
changeDirection = direction
def gameOver():
    gameOverFont = pygame.font.Font('freesansbold.ttf', 72)
    gameOverSurf = gameOverFont.render('Game Over', True, greyColour)
    gameOverRect = gameOverSurf.get_rect()
    gameOverRect.midtop = (320, 10)
    playSurface.blit(gameOverSurf, gameOverRect)
    pygame.display.flip()
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
    for event in pygame.event.get():
        if event.type == QUIT:
            pygame.quit()
            sys.exit()
        elif event.type == KEYDOWN:
            if event.key == K_RIGHT or event.key == ord('d'):
                changeDirection = 'right'
            if event.key == K_LEFT or event.key == ord('a'):
                changeDirection = 'left'
            if event.key == K_UP or event.key == ord('w'):
                changeDirection = 'up'
            if event.key == K_DOWN or event.key == ord('s'):
                changeDirection = 'down'
            if event.key == K_ESCAPE:
                pygame.event.post(pygame.event.Event(QUIT))
        if changeDirection == 'right' and not direction =='left':
            direction = changeDirection
        if changeDirection == 'left' and not direction == 'right':
        if changeDirection == 'up' and not direction == 'down':
        if changeDirection == 'down' and not direction == 'up':
        if direction == 'right':
            snakePosition[0] += 20
        if direction == 'left':
            snakePosition[0] -= 20
        if direction == 'up':
            snakePosition[1] -= 20
        if direction == 'down':
            snakePosition[1] += 20
        snakeSegments.insert(0,list(snakePosition))
        if snakePosition[0] == raspberryPosition[0] and snakePosition[1] == raspberryPosition[1]:
            raspberrySpawned = 0
        else:
            snakeSegments.pop()
        if raspberrySpawned == 0:
            x = random.randrange(1,32)
            y = random.randrange(1,24)
            raspberryPosition = [int(x*20),int(y*20)]
        playSurface.fill(blackColour)
        for position in snakeSegments:
            pygame.draw.rect(playSurface,whiteColour,Rect(position[0], position[1], 20, 20))
            pygame.draw.rect(playSurface,redColour,Rect(raspberryPosition[0], raspberryPosition[1], 20, 20))
        if snakePosition[0] > 620 or snakePosition[0] < 0:
            gameOver()
        if snakePosition[1] > 460 or snakePosition[1] < 0:
            gameOver()
        for snakeBody in snakeSegments[1:]:
            if snakePosition[0] == snakeBody[0] and snakePosition[1] == snakeBody[1]:
                gameOver()
        fpsClock.tick(50)
dcalvo
Re: Problem with Snake game design
Sun Jan 07, 2018 1:09 am
This is what I see from the code you wrote in your message.
pygame.event.get() is a blocking call, so if there is nothing in the queue (neither mouse or keyboard as an example) it doesn't return therefore, it doesn't allow you snake to move. I would change that function and I will give a try to:
pygame.event.peek()
pygame.event.poll()
peek() checks if there is anything waiting on the queue so if there is nothing, it will return false. In that case, you should allow your snake to move a bit keeping the same direction and heading as in the last state. Note: You should add a little delay, otherwise it will move so fast so you won't be able to play with it.
If there is anything on the queue, it will return True and you will get the event with poll() and move accordingly.
I will try to change the code tomorrow,
Hope this helps. Thank you..
gordon77
Sun Jan 07, 2018 9:45 am
1st version moves whilst you hold a key down.. 2nd version will continuously move in last direction
added pygame.key.set_repeat(50,50)
pygame.init()
direction = 'right'
def gameOver():
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
            sys.exit()
        else:
            snakeSegments.pop()
            gameOver()
            gameOver()
                gameOver()
        fpsClock.tick(50)
This version will continue to move in direction set (had to slow it down ! with fpsClock.tick(10))
Moved some code out of pygame event loop.
pygame.init()
direction = 'right'
def gameOver():
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
            sys.exit()
    else:
        snakeSegments.pop()
        gameOver()
        gameOver()
            gameOver()
    fpsClock.tick(10)
resipete
Sun Jan 07, 2018 11:56 am
Thanks a lot for the help, it's working now! :D
Return to “Python”
