For my project, I need a video looper and I found it here:
https://learn.adafruit.com/raspberry-pi ... stallation
It works fine, and to turn off the system I remove the power cable.
But in the above method, they mentioned that you need to connect to raspi board with ssh to shut down the board, because shutting down the raspi by pulling the power cable may cause damage to SD card and in some case maybe need to reinstall the os.
In my project, I need to power on and off my video looper several times in a day. (I do not want to use SSH ) so it's better that have a shutdown button to turn off the raspi.
so is there a method that integrates mentioned video looper with a shutdown button?
any alternative method to do this is appreciated.
Regards
