bnmc_
Issue when setting up RaspAP
Wed Jan 03, 2018 1:40 pm
Hey everyone,
I have just downloaded RaspAP onto my Pi 2 Model B. Upon rebooting, I am now able to see the "raspi-webgui" network on my mobile phone. However, when I enter the default password ChangeMe, it does not seem to connect. Also, when I hover over the Wi-Fi button on the top right corner of the screen, it says "Connection to dhcpcd lost." What is causing this?
My /etc/network/interfaces looks like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
Let me know if there are any other files you would like.
SurferTim
Re: Issue when setting up RaspAP
Wed Jan 03, 2018 1:50 pm
If you are downloading that onto a Stretch OS, you will have problems. APs are set up differently on Stretch. No entries in /etc/network/interfaces except for a bridge.
If you want to set up an access point on Stretch, then use this guide. It has both standalone (NAT) and bridge access points.
https://github.com/SurferTim/documentat ... s-point.md
beta-tester
Wed Jan 03, 2018 2:02 pm
https://www.raspberrypi.org/documentati ... s-point.md
this works as well for stretch - even there is /etc/network/interfaces part included.
unfortunately i have no proper WiFi USB dongle on my RPi2 - my WiFi USB dongle does not support AccessPoint mode :x
maybe yours too.
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
SurferTim
Wed Jan 03, 2018 2:08 pm
Looks like the wifi does have ap capability, but isn't working.
Edit: That tutorial on the RPi site doesn't work for either standalone or bridged access points. Been there. Tried that.
bnmc_
Wed Jan 03, 2018 2:36 pm
If it helps, my wifi adapter is a Ralink RT5370.
SurferTim
Wed Jan 03, 2018 2:43 pm
It is probable that you have a service fail somewhere. I will presume that the app uses dnsmasq for dhcp. Try these:
sudo service dhcpcd status
sudo service dnsmasq status
ifconfig
The two services should show active (running).
Post the output of those if you have questions.
bnmc_
Wed Jan 03, 2018 5:02 pm
ifconfig
The output of the first line is:
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor present: enabled)
Active: failed (Result: exit-code) since Wed 2018-01-03 08:36:47 UTC; 2min 47s ago
Process: 351 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=6)
Then it says "Not running dhcpcd because /etc/network/interfaces defines some interfaces that will use a DHCP client or static address." As such, I am assuming that my /etc/network/interfaces is configured wrongly. I had attached it in the first comment on this thread, so please take a look at it and tell me if anything needs to be changed.
However, dnsmasq shows active and running.
SurferTim
Wed Jan 03, 2018 6:59 pm
In Stretch you don't use /etc/network/interfaces to assign network settings. That is done in /etc/dhcpcd.conf.
bnmc_
Wed Jan 03, 2018 7:07 pm
How is this done?
beta-tester
Wed Jan 03, 2018 9:00 pm
How is this done?
e.g.:
interface wlan0
static ip_address=192.168.1.123/24
static routers=
static domain_name_servers=
