hi I install SLES-12-SP2-ARM-X11-raspberrypi3_aarch64.aarch64-2016.10.04-GM.raw.xz on Raspberry pi 3 model b and run it ok. when I want to run a processing export file for Linux 64 have this problem
I run it with this command : " xinit ./filename"
do I use right command ?
then after run have this error :" Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again."
i remove /tmp/.X0-lock , that say in linked below
" https://www.x.org/wiki/FAQErrorMessages/#index5h2 "
then i run again see error 6 in the linked above that is " _XSERVTransSocketINETCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
Fatal server error:
Cannot establish any listening sockets - Make sure an X server isn't already running "
i don't what is my mistake?
please help me
thanks
