MemeMeme
SD card made read-only due to Pi 3
Mon Jan 01, 2018 9:49 pm
This is not my only problem about the Micro SD card bundled with my RPi. After I'd booted up NOOBS a few times, the card was write-protected. The card had 4 partitions (from Disk Management) and 2 needed formatting. Is there any way I can fix this without Linux?
rpjt17
Re: SD card made read-only due to Pi 3
Tue Jan 02, 2018 3:22 am
MemeMeme wrote: This is not my only problem about the Micro SD card bundled with my RPi. After I'd booted up NOOBS a few times, the card was write-protected. The card had 4 partitions (from Disk Management) and 2 needed formatting. Is there any way I can fix this without Linux?
Well, I am not sure if this would work, but when I need to format a Micro SD Card, I would use diskpart. When I use it, I always find it easy enough for what I am doing. Haven't used diskpart in sometime, but I believe you can format specific partitions.
Hope this helps,
rpijt17
Tue Jan 02, 2018 9:00 am
You need to understand Noobs partioning and the OS on your machine would need to be able to understand EXT Format:
https://github.com/raspberrypi/noobs/wi ... -explained
It may be easier to just install, using Etcher, one OS on the SD Card !
RPi 4B 4GB (SSD Boot)..
jahboater
Tue Jan 02, 2018 10:39 am
+1
and note if you use Etcher there is no need to format the card first or even unzip the image.
