cyclicredundancy
Support for MAX3421E USB host controller
Mon Jan 01, 2018 12:31 am
I am trying to figure out if the raspberry pi has linux drivers for the maxim MAX3421E SPI USB host controller.
https://www.maximintegrated.com/en/prod ... 3421E.html
This is the same chip used in the various USB host shield boards:
https://www.circuitsathome.com/arduino_ ... _projects/
Googling around randomly.... I see that there seems to be code in the linux kernel for this:
https://github.com/torvalds/linux/blob/ ... 3421-hcd.c
And the same code is also there in the raspberry pi kernel source tree:
https://github.com/raspberrypi/linux/bl ... 3421-hcd.c
Is there some way for me to figure out if that driver is supported in Raspbian which is running kernel version 4.9.72 ?
Will the driver be compiled as a module?
I tried a grep and could not locate it under /lib/modules , so does that mean it is not compiled by default?
$ find /lib/modules/ | grep hcd
/lib/modules/4.9.59-v7+/kernel/drivers/usb/usbip/vhci-hcd.ko
/lib/modules/4.9.72+/kernel/drivers/usb/usbip/vhci-hcd.ko
/lib/modules/4.9.72-v7+/kernel/drivers/usb/usbip/vhci-hcd.ko
/lib/modules/4.9.59+/kernel/drivers/usb/usbip/vhci-hcd.ko
If the driver is not preset if it fairly straightforward to add support for it, or build it on my own?
The last time I tried to build a linux kernel was sometime in 2001 :-p so I will pretty much be starting from scratch.
Thanks!
kernel config:
https://cateee.net/lkddb/web-lkddb/USB_MAX3421_HCD.html
email list post where support for this driver was requested to be pulled into the kernel:
https://www.spinics.net/lists/linux-usb/msg104882.html
broe23
Re: Support for MAX3421E USB host controller
Mon Jan 01, 2018 7:19 am
Does Raspbian not see that controller?
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
Mon Jan 01, 2018 9:27 am
You can check the kernel config, which is now held in a module, so you need to load that first, then check the config file.
[email protected]:~ $ sudo modprobe configs
[email protected]:~ $ zgrep MAX3421 /proc/config.gz
# CONFIG_USB_MAX3421_HCD is not set
So that looks like it isn't available in the kernel that I'm currently running (4.9.35-v7+).
You'd need to make a custom kernel to add support.
cezar.santanna
Sat Jun 30, 2018 9:34 pm
Does any one get any success using this chip as USB HOST?
emw
Thu Sep 27, 2018 2:37 pm
Bump. Has anyone had any experience at all with this chip on the PI?
dconnx
Tue Feb 19, 2019 9:58 am
Hi, Did anyone get anywhere (with getting a MAX3421 recognised as a USB controller on the RP SPI bus) ? I'm interested in this too. thanks Derek
emw
Tue Feb 19, 2019 1:34 pm
Yes I have it working on a pi zero w. Do you have any specific questions?
billoo2378
Tue Feb 19, 2019 7:16 pm
The MAX3421E USB peripheral/host controller contains the digital logic and analog circuitry necessary to implement a full-speed USB peripheral or a full-/low-speed host compliant to USB specification rev 2.0. A built-in transceiver features ±15kV ESD protection and programmable USB connect and disconnect.
billoo2378
Wed Feb 20, 2019 11:48 am
:P The MAX3421E USB peripheral/host controller contains the digital logic and analog circuitry necessary to implement a full-speed USB peripheral or a full-/low-speed host compliant to USB specification rev 2.0. A built-in transceiver features ±15kV ESD protection and programmable USB connect and disconnect. An internal serial interface engine (SIE) handles low-level USB protocol details such as error checking and bus retries. The MAX3421E operates using a register set accessed by an SPI interface that operates up to 26MHz. Any SPI master (microprocessor, ASIC, DSP, etc.) can add USB peripheral or host functionality using the simple 3- or 4-wire SPI interface. :P :P :P
scarlyon
Sun Jun 23, 2019 11:49 am
Hi.
I am going to use a barcode scanner with MAX3421E as I can't use the original USB port.
Could you please guide me on how to use that?
Cheers.
emw
Mon Jun 24, 2019 3:48 pm
here are my notes:
''' Note this was originally done with the 4.14 kernel and should be updated for newer versions'''
sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/bin/rpi-source && sudo chmod +x /usr/bin/rpi-source && /usr/bin/rpi-source -q --tag-update
sudo apt-get install bc libncurses5-dev bison flex libssl-dev
rpi-source
This may take a while
back porting is not required for kernel 4.19
cd linux/drivers/usb/host/
mv max3421-hcd.c max3421-hcd.c.old
The next line gets the new version of max3421-hcd.c with device tree support
wget https://raw.githubusercontent.com/torva ... 3421-hcd.c
cd ~/linux
make menuconfig
-> set <M> MAX3421 HCD (USB-over-SPI) support
scripts/diffconfig
should respond with 'USB_MAX3421_HCD n -> m'
grep MAX3421 .config
should respond with 'CONFIG_USB_MAX3421_HCD=m'
make prepare
make SUBDIRS=drivers/usb/host/ modules
sudo make SUBDIRS=drivers/usb/host/ modules_install
above line may create warning
sudo depmod
 cd ~/linux/arch/arm/boot/dts/overlays/
create the file max3421-spi0-overlay.dts
/dts-v1/;
 /plugin/;
         compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
         [email protected] {
         target = <&spidev0>;
                 __overlay__ {
                         status = "disabled";
         /* the interrupt pin of the usb-controller */
         [email protected] {
                 target = <&gpio>;
                 __overlay__ {
                         usb2_pins: usb2_pins {
                                 brcm,pins = <25>;
                                 brcm,function = <0>; /* input */
         [email protected] {
                 target = <&spi0>;
                 __overlay__ {
                         #address-cells = <1>;
                         #size-cells = <0>;
                         pinctrl-names = "default";
                         pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
                         cs-gpios = <&gpio 8 1>;
                         status = "okay";
                         maxim3421: [email protected] {
                                 compatible = "maxim,max3421";
                                 reg = <0>; /* CE0 */
                                 maxim,vbus-en-pin = <3 1>;
                                 interrupt-parent = <&gpio>;
                                 interrupts = <25 8>; /* low irq */
                                 #gpio-controller;
                                 #gpio-cells = <2>;
                                 spi-max-frequency = <10000000>;
then
 sudo dtc [email protected] -I dts -O dtb -o /boot/overlays/max3421-spi0.dtbo max3421-spi0-overlay.dts
this will include 3 warnings '/boot/overlays/max3421-spi0.dtbo: Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property'
 sudo nano /boot/config.txt
  • uncomment
    #dtparam=spi=on
  • add
    dtoverlay=max3421-spi0
    dtoverlay=dwc2
reboot
emw
Mon Jun 24, 2019 3:53 pm
You will also need some hardware, and the above may vary slightly on how/what hardware you use. I used a sparkfun board with a minor power modification (5v is provided from pi rather than lm 1117).
Sparkfun Max3421 to pi wiring
RX
TX
2
3
4
5
6
7
8
9 INT to Pin 22 (GPIO25)
10 SS to Pin 24 (GPIO 8)
11 MOSI to Pin 19 (GPIO 10)
12 MISO to Pin 21 (GPIO9)
13 SCLK to Pin 23 (GPIO11)
G
AREF
AIN5
AIN4
AIN3
AIN2
AIN1
AIN 0
VIN
G
G to Pin 15 (GND)
+5 to Pin 2 (+5)
+3.3
RST
The modification to the board is a jumper wire from +5 (on connector above) to +term of tantalum capacitor beside USB connector
