Thunderbolt044
How to install The Little Crane That Could
Thu Dec 28, 2017 4:58 am
Hello Everyone,
I recently got a Raspberry Pi and I have been having trouble installing The Little Crane That Could. I know where to get the files I just don't know how to install them. Can I get some help? :D
pcmanbob
Re: How to install The Little Crane That Could
Thu Dec 28, 2017 3:32 pm
Hi.
A quick google search tells me this is a game that can be download for android , iOS or Stream.
Android & iOS apps will not run on the pi end of story.
and if you look at the stream Linux version it requires a pc with a corei5 processor as a minimum and 4GB of ram so that's never going to run on the pi either.
Thu Dec 28, 2017 3:36 pm
Hi.
Well what is this then ??
https://stolk.org/tlctc/
littlecrane-rpi.tar.gz
RPi 4B 4GB (SSD Boot)..
hippy
Thu Dec 28, 2017 3:38 pm
A Pi version can be obtained from link below - Click on the "Pi Store Download" button. It's a .tar.gz file ...
I spotted a "doesn't work on Stretch" comment here ...
http://raspberrypimodel.blogspot.co.uk/ ... could.html
pcmanbob
Thu Dec 28, 2017 4:46 pm
I Did say I did a quick google search and that site ( https://stolk.org/tlctc/) was not on page one when I searched "the little crane that could"
I tied installing the version for the pi but it does not seem to work either.
Starting game from /home/pi/littlecrane-rpi
little crane config files go in '/home/pi/.littlecrane'
OPTIMIZED build
Built on Jan 23 2013 at 13:10:56
Does not support depth textures.
Does not support half float textures.
Shader compile log:
Compiled
Compiled vertex shader Hud
Shader compile log:
Compiled
Compiled fragment shader Hud
ERR Program link log:
Shader compile log:
Compiled
Compiled vertex shader MainNS
Shader compile log:
Compiled
Compiled fragment shader MainNS
Shader compile log:
Compiled
Compiled vertex shader ShadowNDT
Shader compile log:
Compiled
Compiled fragment shader ShadowNDT
Shader compile log:
Compiled
Compiled vertex shader Edge
Shader compile log:
Compiled
Compiled fragment shader Edge
Hud program loaded as 1
Main program loaded as 4
Shadow program loaded as 7
Edge program loaded as 10
loading VBOs of geomdb containing 0 entries
Loaded 0 geometry VBOs
ls: cannot access /dev/input/by-id/*-kbd: No such file or directory
fgets failed for ls output: No such file or directory
open of '(null)' FAILED.
open failed: Bad address
tested on jessie with GUI.
installed like this :-
with littlecrane-rpi.tar.gz in /home/pi
tar xvzf littlecrane-rpi.tar.gz
un-packs in to /home/pi/littlecrane-rpi
cd  /home/pi/littlecrane-rpi
chmod +x startlittlecrane.sh
./startlittlecrane.sh
as the original build was on Jan 23 2013 at 13:10:56 the problem may be OS or hardware related.
Thunderbolt044
Fri Dec 29, 2017 2:23 am
So you think the game is just too outdated to run?
pcmanbob
Fri Dec 29, 2017 11:26 am
It may be the case as from the date displayed it was made when raspbian wheezy was the current operating system and the pi B or B+ were the current pi's.
its already been stated it does not work on raspbian stretch and my attempt to run it on jessie met with similar failure.
I suppose you could get a pi B or B+ and download wheezy and try running it that way if you really wanted to try the game but there are no guarantees it will run.
rpiMike
Sun Dec 31, 2017 9:22 am
This works on my Pi3 using Raspbian Stretch (with OpenGL driver off)
cd ~
wget https://stolk.org/tlctc/littlecrane-rpi.tar.gz
cd ~/littlecrane-rpi
To run
LD_LIBRARY_PATH=/opt/minecraft-pi/lib/brcm ./startlittlecrane.sh
Reference : viewtopic.php?f=78&t=191857#p1244393
Thunderbolt044
Sun Dec 31, 2017 4:58 pm
Okay, I will give this a try. Thanks for the help everyone.
