naman1208
Display problem
Wed Dec 27, 2017 5:34 pm
I am using raspberry pi3 with latest raspbian stretch, i am using HDMI to DVI converter for mi raspberry pi and it was working fine but recently i am having problem, when i power on my raspberry pi i am not getting clear display, it is full of red squares and shaking, and after some time it becomes blank.
I am using same cable for my pc and it works fine, so there is no problem in the cable and i have also tried reflashing latest raspbian image but no luck.
Plz help....
ProjectYell0wJack3t
Re: Display problem
Sun Dec 31, 2017 11:49 pm
Im presuming its broken. TV screens use a system called RGB (Red Green and Blue), sometimes if the screen gets hit the Green and Blue lights break. I could be wrong though, what type of monitor are you using?
A few things you could try are:
Changing the resolution or brightness.
Try pressing gently on the red dots, or on the four corners of the screen.
