Stephaude
Ultrasonic Scratch2
Tue Dec 26, 2017 7:29 am
Hello
I use the ultrasonic sensor in scratch 1.4 (ultrasonic + trigger + trigger pin + echo + echo pin). On the other hand, I can not use this sensor in scratch 2. Do you have a solution?
Thank you
Bye
Forris
Raspberry Pi Certified Educator
Re: Ultrasonic Scratch2
Tue Jan 02, 2018 2:45 pm
A bit more info would be useful:
How are you connecting the sensor ?
What does your script look like, in both 1.4 and 2.0 ?
What is it, specifically, that doesn't work ?
ghp
Tue Jan 02, 2018 8:06 pm
since a short time scratchClient is supporting scratch2 in addition to scratch1.4. There is an adapter supporting the ultrasonic sensor.
See http://heppg.de/ikg/wordpress/?p=984 for a summary.
When connecting the ultrasonic HC-SR04, be sure to use level shifters for the output signal. The sensor is powered by 5V.
Hope this helps,
Gerhard
Return to “Scratch”
