Thanks for help
my Project is to calculate the produced power and load Amp of Generator , so that i used SCT-013 100AMP.
the same circuit used with Arduino and it works fine , MCP3008 wiring is correct .
i'm using the following code to test the output but i got 0
# Simple example of reading the MCP3008 analog input channels and printing
# them all out.
# Author: Tony DiCola
# License: Public Domain
import time
# Import SPI library (for hardware SPI) and MCP3008 library.
import Adafruit_GPIO.SPI as SPI
import Adafruit_MCP3008
# Software SPI configuration:
CLK = 23 #18
MISO = 21 #23
MOSI = 19 #24
CS = 24 #25
mcp = Adafruit_MCP3008.MCP3008(clk=CLK, cs=CS, miso=MISO, mosi=MOSI)
# Hardware SPIHardware SPI configuration:
#SPI_PORT = 0
#SPI_DEVICE = 0
#mcp = Adafruit_MCP3008.MCP3008(spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE))
print('Reading MCP3008 values, press Ctrl-C to quit...')
# Print nice channel column headers.
print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*range(8)))
print('-' * 57)
# Main program loop.
while True:
# Read all the ADC channel values in a list.
values = [0]*8
for i in range(8):
# The read_adc function will get the value of the specified channel (0-7).
values[i] = mcp.read_adc(i)
# Print the ADC values.
print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*values))
# Pause for half a second.
time.sleep(0.5)
any help why i'm getting 0 and if i enabled hardware SPI Section i got a random numbers for other pins and 795 for CH0 while it connected to power or not !
