alicantino79
Compatible USB pen drives
Sat Dec 23, 2017 12:08 am
Hello all!
I'm new with the raspberry and I wonder whether I could connect any USB pen drive to the Raspberry Pi 3 model B...
Is there any compatibility list?
Is there any problem with power supply?
Any difference between USB 2.0/3.0?
Thanks in advance!
topguy
Re: Compatible USB pen drives
Sat Dec 23, 2017 1:10 am
Most pendrives should work well. They usually require very little power and are usually backwards compability.
There would be impossible to maintain a list of working or non-working memsticks because there are just too many types of them.
What matter most is probably what filesystem the pendrive/memstick was formatted with.
FTrevorGowen
Sat Dec 23, 2017 6:32 pm
topguy wrote: Most pendrives should work well. They usually require very little power and are usually backwards compability.
+1, however, FWIW, these are the ones "I know about":
http://www.cpmspectrepi.uk/raspberry_pi ... rives.html
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
