Fieel
Windows 10 cannot access samba share
Thu Dec 21, 2017 5:17 pm
i have a problem with samba: i configured Raspbian to share a folder over my LAN, i can access the folder through my two android devices but my Windows 10 desktop PC won't allow me.
I tried everything! Tried to follow a lot of similar threads i found googling but nothing worked. It's probably my windows computer because i can access the folder with other devices!
i can see the raspberry pi with windows explorer like this:
but when i try to access the raspberry i get this message (error code: 0x80070035):
Even if i try to access directly using the ip, i get this message: (error code: 0x80004005):
This happens both if i access the /share/ or /share/folder path.
This is my smb.conf file, sorry about the endless comments:
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
#  - When such options are commented with ";", the proposed setting
#    differs from the default Samba behaviour
#  - When commented with "#", the proposed setting is the default
#    behaviour of Samba but the option is considered important
#    enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
   workgroup = WORKGROUP
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
#   wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
   dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
   max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
#   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
   syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
   panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
   server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
   passdb backend = tdbsam
   obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
   unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
   pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
   map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
#   logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
#   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
;   usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
   usershare allow guests = yes
#======================= Share Definitions =======================
[homes]
   comment = Home Directories
   browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
   read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# The following parameter makes sure that only "username" can connect
# to \\server\username
# This might need tweaking when using external authentication schemes
   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
;   directory mask = 0700
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
;   write list = root, @lpadmin
[web_server]
        path = /var/www/dai-gurren
        writable = yes
        browsable = yes
        guest ok = yes
        public = yes
What could be the problem? I really don't know what else to do.
Fieel
Re: Windows 10 cannot access samba share
Sat Dec 23, 2017 1:09 pm
Guys nobody can really help me? I've been stuck for some days now..
Sat Dec 23, 2017 3:14 pm
akisg
Sat Dec 23, 2017 4:21 pm
Trying myself to make a shared folder from a rpi3 to my network (windows and linux), i used this guide https://raspberrypihq.com/how-to-share- ... pberry-pi/
I can now access the share folder that i created through my network. With my little knowledge so far, i can see that you haven't created any shared path into the smb.conf file, maybe that's the prob. Also, i could see the rpi in the first place into my windows 10 pc network, but it then disappeared, although i can still access the shared folders if i just type the ip address of my rpi into the explorer.
Fieel
Sun Dec 24, 2017 11:48 am
What you mean? My shared folder is at the bottom of the smb.conf file:
[web_server]
writable = yes
browsable = yes
guest ok = yes
public = yes
Fieel
Sun Dec 24, 2017 3:00 pm
Nice interesting article about the problems of SMBv1! Thank you for sharing.
Added
min protocol = SMB2
to my smb.conf file for safety but that didn't fix my issue.
In case someone stumbled upon this thread looking for a solution, i found one. Basically the Error 0x80004005 means "you can't access this shared folder because your organization's security policies block unauthenticated guest access." I noticed my shared folder (as you can see from my smb.conf file i pasted on my first post) was enabled for guests and had no security at all. That wasn't an error, i wasn't interested in security, but i had to change it because apparently windows doesn't appreciate it:
	[global]
		security = user
	[web_server]
	        path = /var/www/website_folder
	        read only = no
 	       writable = yes
 	       browsable = yes
 	       valid users =  *username1*
 	       force user = *username1*
  	      create mask = 0640
  	      directory mask = 0750
Stuff didn't work yet so i tried setting the psw again for my user:
smbpasswd -a *username1*
Now i can access the folder and stuff works correctly.
diman82
Mon Nov 05, 2018 11:33 pm
Set the following registry value to 1
HKLM\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters\AllowInsecureGuestAuth
If its not there create the value as a DWORD
plugs
Tue Jan 22, 2019 11:00 pm
THANKS the regfistry change worked a treat on WIndows 10 1809
subtlenv
Sat Jun 29, 2019 12:35 pm
thanks to diman82 for the fix.
here's my gist for exported reg entry; created this is mainly because I don't have pretty good memory #lol
hope this saves some time -> https://gist.github.com/xyznaveen/850a6 ... f3bea728d7
tengotengo
Wed Aug 21, 2019 6:16 am
this worked! tried everything, finally
TheRiflesSpiral
Fri Mar 27, 2020 7:04 pm
This thread helped me. Thank you so much for running this down and providing the REGEDIT info.
Can I also say that this is completely bonkers. But that's Windows I guess... :D
graham.reeds
Tue Mar 31, 2020 1:51 pm
Running optionalfeatures.exe from the search bar and checking the 'SMB 1.0/CIFS File Sharing support' should work.
I had to do this on several boxes as I lost access to my old NAS.
joaquimparis
Sat Apr 11, 2020 9:27 pm
Worked fine. thanks.
I know very well what it means for the security of my system, but this is a controled environment and that's fine.
Now that I know it, I can script this change on and off whenever I take my notebook out.
Long Live Pis
Return to “Raspberry Pi OS”
