siansoft
Running AIY Google Assistant On Boot-up on Raspberry pi3
Thu Dec 21, 2017 10:47 am
Hi All :)
How can I run AIY Google Assistant on the boot-up on raspberry pi 3 without the need of monitor? I try to make a .sh file and i put the code below but it's not working? I try to make a .sh file and i put the code below but it's not working
#!/bin/sh
cd /
cd /home/pi
cd AIY-voice-kit-python/src
sudo python assistant_library_demo.py
cd /
jrtapiajr
Re: Running AIY Google Assistant On Boot-up on Raspberry pi3
Thu Dec 21, 2017 10:22 pm
goto misperry youtube website and search for "google assistant auto startup" video. He does a good job showing how to write a script for auto start up. I had to change the part where he said to type "google-assistant-demo& ....to get in running in the background." I had to add the "registration information" project id and device Id name. This information can be taken from the registration setup on the google SDK developer website. the guide shows you how to register your device so the google assistant can work right. This additional step is due to the recent update of the SDK as of yesterday.
avzdkdk
Sun Dec 31, 2017 8:38 am
I have added one line to the crontab.
@reboot sleep 120 && cd /home/pi/AIY-voice-kit-python && /home/pi/AIY-voice-kit-python/env/bin/python3 /home/pi/AIY-voice-kit-python/src/assistant_library_demo.py > /home/pi/error.txt 2>&1
Maybe that will help
mpember
Sun Dec 31, 2017 12:39 pm
The official method is to create a file called main.py (by copying one of the examples or creating a new file) and execute the install-services.sh script (in the scripts folder).
Once you have done this,
sudo systemctl enable voice-recognizer.service
will turn on the service and have it run at boot.
RichardBronosky
Tue Jan 02, 2018 7:29 am
Yes, mpember is correct. Please do not use (or spread) methods involving `crontab`, `rc.local`, etc. Raspbian (like all modern distrobutions) uses systemd, and that is the way we do this.
For reference I will add a few links.
HACKING.md explains how to enable the included services. Those instructions assume you have follow the prior instructions on that same page to install the service scripts. If you have done so, then you can make a copy of assistant_library_with_local_commands_demo.py called `main.py` (in that same location).
Since you will certainly be hacking your assistant for a while, be aware of these commands:
sudo systemctl stop voice-recognizer.service
sudo systemctl start voice-recognizer.service
sudo systemctl restart voice-recognizer.service
-- Bruno Bronosky
1x RPi 1 (B)
1x RPi 1+ (B)
2x RPi 2
11x RPi 3
4x RPi Zero W
2x RPi camera module
3x AIY Voice kits
https://github.com/RichardBronosky/pi-gen-extender
https://github.com/RichardBronosky/raspbian-boot-setup
1car69
Thu Mar 01, 2018 11:00 am
:D
Thank you RichardBronosky & mpember. You have saved the day. Worked like a charm at my end!
joostvb
Fri Mar 02, 2018 6:07 pm
Hi Guys,
i just can't get it to work :(
Service installs, w/o errors, i have a "main.pi" in the source dir, BUT service status says:
● voice-recognizer.service - voice recognizer
Loaded: loaded (/lib/systemd/system/voice-recognizer.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2018-03-02 17:52:50 UTC; 9min ago
Main PID: 1456 (code=exited, status=203/EXEC)
Mar 02 17:52:50 raspberrypi systemd[1]: voice-recognizer.service: Service hold-off time over, scheduling restart.
Mar 02 17:52:50 raspberrypi systemd[1]: Stopped voice recognizer.
Mar 02 17:52:50 raspberrypi systemd[1]: voice-recognizer.service: Start request repeated too quickly.
Mar 02 17:52:50 raspberrypi systemd[1]: Failed to start voice recognizer.
Mar 02 17:52:50 raspberrypi systemd[1]: voice-recognizer.service: Unit entered failed state.
Mar 02 17:52:50 raspberrypi systemd[1]: voice-recognizer.service: Failed with result 'exit-code'.
1car69
Sun Mar 04, 2018 5:42 pm
Try "main.py" saved in the examples directory... in the same directory where the demo example that you copied and renamed "main.py" resides.
Jagman53
Fri Mar 09, 2018 11:26 pm
Hi. I am a noob, so please bear with me. I got the same error message as joostvb after checking the status of the .service file I made. What should I do?
513Kernal
Fri Mar 16, 2018 2:31 pm
Can you go a little more in depth with this?? I also received this same error, and I'm REALLY new to all of this
Fri Mar 16, 2018 5:30 pm
Simplest way (no YT video watching needed)
Create a file with sudo nano /etc/systemd/system/assist.service
[Unit]
Description=Assist @ reboot
[Service]
ExecStart=/home/pi/assist.py
User=pi
Group=pi
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=assist
[Install]
WantedBy=multi-user.target
Enable it (for next boot) with sudo systemctl enable assist.service
Start it with sudo systemctl start assist.service
That's got Miss Google listening on my RPi3B+ at every boot.
You can change her into Mister Google with, "OK Google, change your voice" ... <wait for response> ... then say, "Yes".
themaire
Fri Mar 16, 2018 8:03 pm
Hi Dougie, did you install the Voice hat manualy? I never do it myself but i wait to use my new 3 B+ very soon.
All my Raspberry Pi stuffs on my Twitter : @nico_themaire
:D
Fri Mar 16, 2018 9:09 pm
I installed it by git clone https://github.com/google/aiyprojects-raspbian; ln -s aiyprojects-raspbian AIY-projects-python.
That's so I got the latest stuff from Dr. Google including ten month's worth of software fixes and enhancements.
I'm running it on my "early support" RPi3B+, which I've had since the start of February.
themaire
Sat Mar 17, 2018 10:02 am
Nice thanks you!
Ho, it is simple like a git clone? Cool. Because i am french, i use the cloud speech api only. I will send a feedback when it’s ok. :)
:D
thecoconutdream
Sat Mar 17, 2018 11:35 am
I have the same problem....I did everything exactly like this: https://aiyprojects.withgoogle.com/voic ... omatically
But my auto start always fails.... I got the feeling that env/bin/.... does not work correctly with the current image... Can you help me?
WhatsApp Image 2018-03-17 at 12.29.56.jpeg (178.53 KiB) Viewed 12521 times
Sat Mar 17, 2018 11:47 am
Nice thanks you!
Ça ne fait rien.
garyst1981
Mon Mar 19, 2018 1:05 pm
what worked for me is combined 2 of the solutions here
cd ~/AIY-projects-python/src/examples/voice
then copied one of the examples and renamed it
cp assistant_library_demo.py main.py
then create the service file
with a little mod from the original poster, instead of using
/home/pi/assist.py
used
/home/pi/AIY-projects-python/src/examples/voice/main.py
to have it like this
[Unit]
[Service]
ExecStart=/home/pi/AIY-projects-python/src/examples/voice/main.py
User=pi
Group=pi
cmd + x, y, enter
then in the terminal
to enable it
then started it
turned rpi off
sudo shutdown -h now
then back ON, and that's it!
JohnOCFII
Sat Mar 31, 2018 1:59 am
Anyone else running into the DBUS X11 display issue when attempting this setup?
From var/log/messages:
Mar 30 22:05:43 raspberrypi pulseaudio[849]: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
Mar 30 22:05:43 raspberrypi pulseaudio[849]: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
It appears it expects to run under a live graphics terminal session.
I found this explanation -- and it implies it isn't really a "bug." They suggest that apps that use pulseaudio, for example, should ignore the error and continue to run, but it appears this demo app from Google does not.
https://bugs.debian.org/cgi-bin/bugrepo ... bug=690530
I can try to implement their suggested workaround in the launch script, but was curious if others had found a better solution.
Thanks,
John
MrCreightonD
Thu Apr 05, 2018 3:03 am
Thank you so much garyst1981! I looked and I looked for a solution to no avail. That is until I cam across your post. However, I did have to mod your solution slightly to get past the enabling step.
I added
[Install]
onto the bottom of your assist.service file. So it should look like this:
[Unit]
[Service]
User=pi
Group=pi
[Install]
/home/pi/assist.py
used
[Unit]
[Service]
User=pi
Group=pi
cmd + x, y, enter
to enable it
then started it
turned rpi off
kevinzhou92
Mon Jun 11, 2018 1:26 am
Thanks,
John
Hey John, i met exactly the same problem like yours, did you figure out how to deal with it?
Mon Jun 11, 2018 9:05 am
I fixed it by running the assistant from the LXDE autostart.
[email protected]:~/.config/lxsession/LXDE-pi $ cat autostart
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@point-rpi
@/usr/bin/python3 /home/pi/assist.py
pnobrega
Mon Jan 14, 2019 12:37 am
[Unit]
[Service]
User=pi
Group=pi
[Install]
Hey...
I've done all this stuff and got not errors.. i've check if the service is running using
[email protected]:~ $ systemctl is-active assist.service
active
and i's active... still GA doesn't work.. If i execute manually the assist.py in ther terminal and keep it running all runs ok...
any ideas?
thanks
garyst1981
Mon Jan 14, 2019 1:09 am
@pnobrega
Look at my answer and @MrCreightonD's after mine
Mon Jan 14, 2019 1:18 am
pnobrega
Mon Jan 14, 2019 1:56 am
@pnobrega
hey. I did that before... and unless i'm missing something it's only changing the directory where the file is... I had errors saying the assist.service didnt existed so I did it like @DougieLawson and used the file from pi folder...
maybe i'm missing something... to many hours... lol
Return to “AIY Projects”
