zslevi0
Serious Sam: TSE
Thu Dec 21, 2017 10:45 am
Hey Everyone,
I've seen somewhere a video of someone playing Serious Sam on an RPi 3, which was one of my favourite childhood games, so I thought I'd give it a try too. Croteam published the source code of their first Serious Engine, someone modified it to make it work on Linux, then ptitseb modified it to run well on ARM code (mainly for Open Pandora).
I compiled and tested it, and it is working amazingly well, on 1024x600 on Quality settings it runs between 40-60 fps, which is enough for an enjoyable gameplay. I thought I'd share how I got it to work since this is currently the best game on RPi in my opinion.
I used this version: https://github.com/ptitSeb/Serious-Engine
Prerequisites:
- Raspberry Pi 3
- Raspbian Stretch (latest)
- Original Serious Sam game files (I have the original CD and copied the files from it.)
- Network connection
Installing:
- Install raspbian on a microSD card then start your RPi.
- Update your system:
sudo apt update
sudo apt upgrade
- Update the firmware:
sudo rpi-update
- Select proper OpenGL driver & set GPU memory to 128M:
sudo raspi-config
Advanced Options --> Memory Split --> 128
Advanced Options --> GL driver -> GL (Full KMS)
Reboot when finished.
- Install the necessary dependencies:
sudo apt install flex bison cmake libvorbis-dev libogg-dev libsdl2-dev
- Download the engine:
git clone https://github.com/ptitSeb/Serious-Engine.git
- Then go to Serious-Engine/Sources directory
- Edit build-linux64.sh file, and comment out the first two lines of code and add NCPU=5 like this:
#NCPU=`cat /proc/cpuinfo |grep vendor_id |wc -l`
#let NCPU=$NCPU+2
NCPU=5
- Set the flag to Release in build-linux64.sh then save. IT IS IMPORTANT! If you do not set it to Release then the average fps will be half of what it should be.
- Just type in the following and wait to finish:
./build-linux64.sh
- After the compilation finished, copy executables and libs:
cp cmake-build/ssam ../Bin/
cp cmake-build/Debug/* ../Bin/Debug/
- Copy original game files into Serious-Engine directory (*.gro files, Levels, Demos etc.)
That is it, now you can start the game from Serious-Engine directory using this command:
Bin/ssam
Here's a video of the first run: https://www.youtube.com/watch?v=MDKdhcvZ4Ec
First Ecnounter also works, you just need to use -DTFE=True flag in build-linux64.sh file.
Please keep in mind that the game has some issues, e.g. NETRICSA/Menu Animation is not working properly, some rendering glitches, missing graphical effects.
ptitSeb
Re: Serious Sam: TSE
Fri Dec 22, 2017 1:07 pm
Nice tuto.
I was wondering what was wrong with latest code that broke RPi build, but I think I found it. If you can try with latest sources code from the github repo :)
Also, sliglty chnages the build-linux64.sh so you can pass the "-DTFE=true" to it.
About the graphical glitches, I'm surprised. On the Pandora (and ODroid IIRC), I don't have any graphical glitches now. It's all working correctly. So maybe this is linked to the OpenGL driver? If you can try using GLES driver (closed sources?) and with gl4es and see if you still have graphical issue with this configuration.
zslevi0
Wed Dec 27, 2017 9:58 pm
Nice tuto.
Ohh, thank you for having a look at it :) I will try it in the following days and post the results.
salvaliebana
Fri May 18, 2018 2:36 am
what do you mean with "set the flag to release"??
jdonald
Mon Dec 24, 2018 4:01 am
It refers to that line in build-linux64.sh that says cmake -DCMAKE_BUILD_TYPE=Debug .. $1: change Debug to Release. Though judging from your video you already got things figured out.
I tried gl4es with ssam, but wouldn't recommend it for others. The first problem I had to sort out was that if I don't configure enough GPU memory the whole system will lock up on loading. After giving 256 MB to the GPU it launches, but every second or so the game unexplicably lags then I recover by either waiting several seconds or pressing Esc, Esc.
Whereas with the Mesa VC4 driver it's quite playable. Framerate varies from 20 to 60 fps but I haven't noticed any obvious graphical glitches with NETRICSA or otherwise. Thanks for sharing, zslevi0!
Gavinmc42
Mon Dec 24, 2018 6:14 am
Don't remember playing Serious Sam, but the specs for SS1 look pretty low and the source is available :D
20-60fps on Raspbian with OpenGL on?
I'm dancing on Rainbows.
Return to “Gaming”
