falken1701
Use I2C with Ruby
Mon Oct 15, 2012 8:43 am
hello,
i try to access the I2C bus with ruby on rails. I search the net for some information. The wiringpi gem seems to be a way, but from my point of view it is used to access the GPIO I/O's and not to access the I2C bus. Has someone tryed something like this?
regards
michael
joan
Re: Use I2C with Ruby
Mon Oct 15, 2012 10:05 am
There is a proper i2c device. I'd use that as it's likely to be much simpler than rolling your own with wiringPi.
If you use the device I2C is accessed like any other file.
Have a look at http://www.raspberrypi.org/phpBB3/viewt ... 19#p191519
falken1701
Tue Oct 16, 2012 7:16 am
Hello Joan,
i read all this exaples befor. But there be only python and C exaples. I search for a way to access the I2C with ruby on rails.
regards
Michael
schroeder
Wed Oct 17, 2012 8:54 am
The only way is to use the c example via ruby ffi. That needs some c knowlege. I want to acess i2c via ruby too. But i didn't have to right it atm.
mikec79
Thu Oct 18, 2012 1:00 am
I'm also trying to learn how to use I2C with Ruby. In my case, I'm trying to use a LSM303 Tilt Compensated Compass from sparkfun. https://www.sparkfun.com/products/10703
Steps I've done so far:
  • Install ruby
  • connect LSM303 to r-pi
  • Test connection with i2cdetect
  • Experiment in irb
require "i2c/i2c"
@lsm303 = ::I2C.create("/dev/i2c-0")
@lsm303.read(0x1E, 0x02)
@lsm303.read(0x1E, 0x03)
I've also found the following:
https://github.com/meinside/raspi-adafr ... 8matrix.rb
mikec79
Fri Oct 19, 2012 2:21 am
I've also tried a different method from the command line.
[email protected]:~$ i2cset -y 0 0x1e 0x00 0x14
[email protected]:~$ i2cset -y 0 0x1e 0x02 0x00
[email protected]:~$ i2cget -y 0 0x1e 0x02
0x00
[email protected]:~$ i2cget -y 0 0x1e 0x03
0xff
[email protected]:~$ i2cget -y 0 0x1e 0x04
0x44
[email protected]spberrypi:~$ i2cget -y 0 0x1e 0x05
0x01
[email protected]:~$ i2cget -y 0 0x1e 0x06
0x4f
[email protected]:~$ i2cget -y 0 0x1e 0x07
0xfe
[email protected]:~$ i2cget -y 0 0x1e 0x08
0x93
here's what I think is the equivalent in ruby:
require "i2c/i2c"
require "i2c/backends/i2c-dev"
@lsm303.write(0x1E, 0x00, 0x14)
@lsm303.write(0x1E, 0x02, 0x00)
puts @lsm303.read(0x1E, 0x02)
puts @lsm303.read(0x1E, 0x03)
puts @lsm303.read(0x1E, 0x04)
puts @lsm303.read(0x1E, 0x05)
puts @lsm303.read(0x1E, 0x06)
puts @lsm303.read(0x1E, 0x07)
puts @lsm303.read(0x1E, 0x08)
But my results don't quite match
?A
R?
??A
R??
?AR??
?AR??
?AR??
mikec79
Fri Oct 19, 2012 3:26 am
I think I'm getting closer. I need to read up on the unpack method and the << operator
require "i2c/i2c"
mag_data = Array.new
(3..8).each do |i|
	mag_data.push  @lsm303.read(0x1E, 0x02)
end
Mx = (mag_data[0] << 8) + mag_data[1]
My = (mag_data[2] << 8) + mag_data[3]
Mz = (mag_data[4] << 8) + mag_data[5]
puts Mx.unpack("C")[0]
puts My.unpack("C")[0]
puts Mz.unpack("C")[0]
