pizzaboy150
Raspberry Pi Dcc Model Railway Controller
Wed Dec 20, 2017 9:46 am
Hi All,
I have been working on a dcc commander for my model railway and using the raspberry pi to control it all.
It has been surprisingly easy to do so thought I would share my code and circuit in case anyone else was trying to do similar.
It is very basic at the minute but does provide enough to get up and running.
The library consists just of a header file which is dcc.h and uses the wiring pi library.
Some helpfull links to below;
http://www.dccwiki.com/Digital_packet
https://www.nmra.org/index-nmra-standar ... -practices
To compile and run the software you will need;
g++
make
wiringPi
to install run;
sudo apt-get install g++ make wiringPi
The circuit I used is a simple H bridge with 2 inputs(input to the circuit, outputs from the PI!) from the raspberry pi and 2 outputs which go to each rail of the track;
The makefile I used to compile the project;
#makefile
all:
        g++ -O3 -Wall main.cpp -o train.bin -lwiringPi
The include file with the instructions;
dcc.h
A simple set of functions to get up and running with DCC using the Raspberry pi.
To use the library you will need wiringPi installed on the pi!
sudo apt-get install wiringPi -y
after that you will first need to run dccSetup(int pin1, int pin2) replacing pins
with the 2 pins used in your circuit. The default pins are 0 and 2 with the wiringPi
pin numbers.
To see the wiringPi pin numbers then run the following command
gpio readall
Once setup has run you build the packet to send by the function
buildPacket(int dir, int address, int speed)
dir is direction with 1 meaning forward and 0 backwards
address is the train address i.e 3 for address 00000011
then speed which is between 0 and 27 max
0 is full stop and between 0 and 27 are increments of speed
//Check if library is already included?
#ifndef __DCC_LIBRARY__
#define __DCC_LIBRARY__
#include <wiringPi.h>
//wiring pi pin numbers
int pinA = 2;
int pinB = 0;
const char preamble[] = {1,1,1,1, 1,1,1,1, 1,1};
char address[8];
char packet[] = {1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,1,1,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,1,1,1};
const char steps[][5] = {{0,0,0,0,0},{0,0,0,1,0},{1,0,0,1,0},{0,0,0,1,1},{1,0,0,1,1},{0,0,1,0,0},{1,0,1,0,0},{0,0,1,0,1},{1,0,1,0,1},{0,0,1,1,0},{1,0,1,1,0},{0,0,1,1,1},{0,1,0,0,0},{1,1,0,0,0},{0,1,0,0,1},{1,1,0,0,1},{0,1,0,1,0},{1,1,0,1,0},{0,1,0,1,1},{1,1,0,1,1},{0,1,1,0,0},{1,1,1,0,0},{0,1,1,0,1},{1,1,1,0,1},{0,1,1,1,0},{1,1,1,1,0},{0,1,1,1,1},{1,1,1,1,1}};
//Speed max number = 27
//address is train number in int form
//direction os 1 for forward and 0 for backwards
void buildPacket(int dir, int address, int speed) {
	//error checking input variables
	if(speed > 27) {
		speed = 27;
	if(speed < 0) {
		speed = 0;
	if(dir > 1) {
		dir = 1;
	if(dir < 0) {
		dir = 0;
	//okay lets build a packet with the data input
	int pos = 0;
	//preamble first
	for(int i = 0; i < (int)(sizeof(preamble) / sizeof(char)); i++) {
		packet[i] = preamble[i];
		pos ++;
	//add the end bit
	packet[pos] = 0;
	pos ++;
	//next lets add the address to the packet
	//but first we need to turn it into 1's and 0's
	int aBit = pos;
	char a[8];
	a[0] = (address & 0b10000000) >> 7;
	a[1] = (address & 0b01000000) >> 6;
	a[2] = (address & 0b00100000) >> 5;
	a[3] = (address & 0b00010000) >> 4;
	a[4] = (address & 0b00001000) >> 3;
	a[5] = (address & 0b00000100) >> 2;
	a[6] = (address & 0b00000010) >> 1;
	a[7] = (address & 0b00000001);
	for(int i = 0; i < 8; i++) {
		packet[pos] = a[i];
		pos ++;
	//add the end bit
	packet[pos] = 0;
	pos++;
	int dBit = pos;
	//now for the direction and speed
	packet[pos] = 0;
	pos++;
	packet[pos] = 1;
	pos++;
	packet[pos] = dir;
	pos++;
	for(int i = 0; i < 5; i++) {
		packet[pos] = steps[speed][i];
		pos++;
	//add the end bit
	packet[pos] = 0;
	pos++;
	//error checking
		if(packet[aBit+i] == packet[dBit+i]) {
			packet[pos] = 0;
			pos++;
		else {
			packet[pos] = 1;
			pos++;
	//add the end bit
	packet[pos] = 1;
//Send the packet to the train using the desired two pins for the H-Bridge circuit
void sendPacket() {
	//get the packet size so we know how many bits to send
	int length = sizeof(packet) / sizeof(char);
	//loop through sending bits
	for(int i = 0; i < length; i++) {
		//always turn a pin off before turning on!!!
		//check for 1 or 0?
		if(packet[i] == 1) {
			digitalWrite(pinA, LOW);
			digitalWrite(pinB, HIGH);
			delayMicroseconds(58);
			digitalWrite(pinB, LOW);
			digitalWrite(pinA, HIGH);
		else {
			delayMicroseconds(100);
//just turns off both pins so no power is going through the track
void dccClose() {
//Simple function which must be called first to start the library and set up the pins and wiring pi
//p1 and the p2 are the pin numbers used as found in the wiring pi library. To check this simply
//type gpio readall and see which pins you want to use. The dault is pin0 and pin2. the order
//doesn't matter
void dccSetup(int p1 = 0, int p2 = 2) {
	//Setup the pins
	pinA = p1;
	pinB = p2;
	//Start library
	wiringPiSetup();
	//setup the pins
	pinMode(pinA, OUTPUT);
	pinMode(pinB, OUTPUT);
#endif
And I have created a simple program which uses the header file to control the train on address no. 3
#include <iostream>
#include <thread>
#include <mutex>
#include "dcc.h"
using namespace std;
mutex mu;
int cmd = 0;
int _dir = 1;
int _speed = 0;
int _address = 3;
bool session = true;
void runPacket() {
	//build the packet
	while(session) {
		mu.lock();
		buildPacket(_dir, _address, _speed);
		mu.unlock();
		sendPacket();
int main(int argc, char * argv[]) {
	cout << "Steve's Dcc Train Commander" << endl;
	cout << "------------------------------------" << endl;
	//setup dcc
	dccSetup();
	//create and run the thread
	thread t(&runPacket);
	//Simply type 100 to quit
	//lazy but easy
	while(cmd != 100) {
		cout << "Speed setting : " << flush;
		cin >> cmd;
		mu.lock();
		if(cmd > 0 && cmd < 28) {
			_dir = 1;
			_speed = cmd;
		else if(cmd < 0 && cmd > -28) {
			_dir = 0;
			_speed = -cmd;
		else {
			_dir = 1;
			_speed = 0;
		mu.unlock();
	//close the thread and get it to rejoin!
	session = false;
	t.join();
	//cleanup
	dccClose();
	return 0;
The code is by no means perfect but it does give a general idea of how things work.
AJB2K3
Re: Raspberry Pi Dcc Model Railway Controller
Sat Dec 23, 2017 6:53 pm
Nice, will have to get my track out and test sometime.
Have you looked into Open DCC?
https://www.opendcc.de/index_e.html
Back in the old days, we were smarter then the technology.
Nowadays technology makes us look like villages fools in front of the children!
AJB2K3
Fri Dec 29, 2017 10:03 pm
Hi All,
g++
make
wiringPi
to install run;
#makefile
all:
dcc.h
pin numbers.
gpio readall
int pinA = 2;
int pinB = 0;
char address[8];
	if(speed > 27) {
		speed = 27;
	if(speed < 0) {
		speed = 0;
	if(dir > 1) {
		dir = 1;
	if(dir < 0) {
		dir = 0;
	int pos = 0;
	//preamble first
		pos ++;
	//add the end bit
	packet[pos] = 0;
	pos ++;
	int aBit = pos;
	char a[8];
		packet[pos] = a[i];
		pos ++;
	//add the end bit
	packet[pos] = 0;
	pos++;
	int dBit = pos;
	packet[pos] = 0;
	pos++;
	packet[pos] = 1;
	pos++;
	packet[pos] = dir;
	pos++;
		pos++;
	//add the end bit
	packet[pos] = 0;
	pos++;
	//error checking
			packet[pos] = 0;
			pos++;
		else {
			packet[pos] = 1;
			pos++;
	//add the end bit
	packet[pos] = 1;
void sendPacket() {
		//check for 1 or 0?
		else {
void dccClose() {
//doesn't matter
	//Setup the pins
	pinA = p1;
	pinB = p2;
	//Start library
	wiringPiSetup();
	//setup the pins
#endif
#include <iostream>
#include <thread>
#include <mutex>
#include "dcc.h"
mutex mu;
int cmd = 0;
int _dir = 1;
int _speed = 0;
int _address = 3;
void runPacket() {
	//build the packet
	while(session) {
		mu.lock();
		mu.unlock();
		sendPacket();
	//setup dcc
	dccSetup();
	//lazy but easy
	while(cmd != 100) {
		cin >> cmd;
		mu.lock();
			_dir = 1;
			_speed = cmd;
			_dir = 0;
			_speed = -cmd;
		else {
			_dir = 1;
			_speed = 0;
		mu.unlock();
	session = false;
	t.join();
	//cleanup
	dccClose();
	return 0;
What recievers are you using in the loco?
