Sure. Full dmesg output:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.35-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80c6ee40, node_mem_map b9faa000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @b9f64000 s25600 r8192 d23552 u57344
[ 0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936296K/966656K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22168K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c79014 ( 485 kB)
.bss : 0x80c7b000 - 0x80d3da64 ( 779 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000335] Console: colour dummy device 80x30
[ 0.001223] console [tty1] enabled
[ 0.001277] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001346] pid_max: default: 32768 minimum: 301
[ 0.001706] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001749] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002771] Disabling cpuset control group subsystem
[ 0.002965] CPU: Testing write buffer coherency: ok
[ 0.003033] ftrace: allocating 22390 entries in 66 pages
[ 0.055365] CPU0: update cpu_capacity 1024
[ 0.055435] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.055534] Setting up static identity map for 0x100000 - 0x100034
[ 0.057780] CPU1: update cpu_capacity 1024
[ 0.057788] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.058503] CPU2: update cpu_capacity 1024
[ 0.058510] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.059178] CPU3: update cpu_capacity 1024
[ 0.059185] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.059268] Brought up 4 CPUs
[ 0.059440] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.059470] CPU: All CPU(s) started in HYP mode.
[ 0.059496] CPU: Virtualization extensions available.
[ 0.060319] devtmpfs: initialized
[ 0.071313] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.071634] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.071696] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.072260] pinctrl core: initialized pinctrl subsystem
[ 0.073184] NET: Registered protocol family 16
[ 0.075441] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.084291] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.084339] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.084512] Serial: AMBA PL011 UART driver
[ 0.086411] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.086956] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[ 0.087320] irq: no irq domain found for /soc/[email protected] !
[ 0.155964] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[ 0.157834] SCSI subsystem initialized
[ 0.158011] usbcore: registered new interface driver usbfs
[ 0.158112] usbcore: registered new interface driver hub
[ 0.158227] usbcore: registered new device driver usb
[ 0.164920] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[ 0.166316] clocksource: Switched to clocksource arch_sys_counter
[ 0.213193] VFS: Disk quotas dquot_6.6.0
[ 0.213303] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.213530] FS-Cache: Loaded
[ 0.213795] CacheFiles: Loaded
[ 0.225981] NET: Registered protocol family 2
[ 0.226927] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.227065] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.227275] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.227388] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.227455] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.227691] NET: Registered protocol family 1
[ 0.228124] RPC: Registered named UNIX socket transport module.
[ 0.228156] RPC: Registered udp transport module.
[ 0.228184] RPC: Registered tcp transport module.
[ 0.228211] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.229156] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.231466] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.247623] FS-Cache: Netfs 'nfs' registered for caching
[ 0.248625] NFS: Registering the id_resolver key type
[ 0.248675] Key type id_resolver registered
[ 0.248703] Key type id_legacy registered
[ 0.251158] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.251316] io scheduler noop registered
[ 0.251346] io scheduler deadline registered (default)
[ 0.251657] io scheduler cfq registered
[ 0.257332] BCM2708FB: allocated DMA memory fa910000
[ 0.257386] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ 0.266086] Console: switching to colour frame buffer device 82x26
[ 0.273558] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.277466] bcm2835-aux-uart 3f215040.serial: could not get clk: -517
[ 0.280802] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.283218] vc-cma: Videocore CMA driver
[ 0.285576] vc-cma: vc_cma_base = 0x00000000
[ 0.287975] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.290243] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.292603] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.312095] brd: module loaded
[ 0.323004] loop: module loaded
[ 0.325095] Loading iSCSI transport class v2.0-870.
[ 0.327792] usbcore: registered new interface driver smsc95xx
[ 0.329931] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.560035] Core Release: 2.80a
[ 0.562091] Setting default values for core params
[ 0.564218] Finished setting default values for core params
[ 0.766795] Using Buffer DMA mode
[ 0.768919] Periodic Transfer Interrupt Enhancement - disabled
[ 0.771161] Multiprocessor Interrupt Enhancement - disabled
[ 0.773394] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.775584] Dedicated Tx FIFOs mode
[ 0.778051] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[ 0.782487] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.793824] dwc_otg: Microframe scheduler enabled
[ 0.793869] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058ef90
[ 0.796165] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f300 length 36
[ 0.798484] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
[ 0.800852] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.803169] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.805530] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.807871] Init: Port Power? op_state=1
[ 0.810128] Init: Power Port (0)
[ 0.812505] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.814816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.817136] usb usb1: Product: DWC OTG Controller
[ 0.819383] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
[ 0.821652] usb usb1: SerialNumber: 3f980000.usb
[ 0.824727] hub 1-0:1.0: USB hub found
[ 0.826965] hub 1-0:1.0: 1 port detected
[ 0.829699] dwc_otg: FIQ enabled
[ 0.829703] dwc_otg: NAK holdoff enabled
[ 0.829707] dwc_otg: FIQ split-transaction FSM enabled
[ 0.829721] Module dwc_common_port init
[ 0.829961] usbcore: registered new interface driver usb-storage
[ 0.832287] mousedev: PS/2 mouse device common for all mice
[ 0.835357] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.837917] bcm2835-cpufreq: min=600000 max=1200000
[ 0.840560] sdhci: Secure Digital Host Controller Interface driver
[ 0.842875] sdhci: Copyright(c) Pierre Ossman
[ 0.845398] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 0.849988] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.852527] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.857580] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.860225] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.862883] usbcore: registered new interface driver usbhid
[ 0.865340] usbhid: USB HID core driver
[ 0.868586] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[ 0.872800] Initializing XFRM netlink socket
[ 0.875336] NET: Registered protocol family 17
[ 0.877975] Key type dns_resolver registered
[ 0.880787] Registering SWP/SWPB emulation handler
[ 0.883938] registered taskstats version 1
[ 0.886734] vc-sm: Videocore shared memory driver
[ 0.889240] [vc_sm_connected_init]: start
[ 0.892160] [vc_sm_connected_init]: end - returning 0
[ 0.899596] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.906964] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 220, base_baud = 50000000) is a 16550
[ 0.912631] sdhost: log_buf @ ba907000 (fa907000)
[ 0.986343] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.991054] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.993542] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.046504] Indeed it is in host mode hprt0 = 00021501
[ 1.109054] of_cfs_init
[ 1.111491] of_cfs_init: OK
[ 1.114251] Waiting for root device /dev/mmcblk0p2...
[ 1.127097] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.130919] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.131318] random: fast init done
[ 1.136860] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.141923] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.177934] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.185633] mmc0: new high speed SDHC card at address aaaa
[ 1.188705] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[ 1.193783] mmcblk0: p1 p2
[ 1.246355] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.248795] Indeed it is in host mode hprt0 = 00001101
[ 1.250984] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.251028] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.258852] devtmpfs: mounted
[ 1.319563] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[ 1.321495] mmc1: new high speed SDIO card at address 0001
[ 1.486643] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.489299] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.492751] hub 1-1:1.0: USB hub found
[ 1.495405] hub 1-1:1.0: 5 ports detected
[ 1.631607] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 1.637479] systemd[1]: Detected architecture 'arm'.
[ 1.759725] NET: Registered protocol family 10
[ 1.763823] systemd[1]: Inserted module 'ipv6'
[ 1.770927] systemd[1]: Set hostname to <pp-mitino-1>.
[ 1.816400] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.956759] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.959473] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.965069] smsc95xx v1.0.5
[ 2.060044] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2d:99:4c
[ 2.215883] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 2.224142] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 2.235842] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.241926] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.247919] systemd[1]: Starting Remote File Systems (Pre).
[ 2.254601] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.778329] systemd-udevd[148]: starting version 215
[ 3.109892] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 3.448994] usbcore: registered new interface driver brcmfmac
[ 3.519264] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.609316] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[ 3.871985] systemd-journald[145]: Received request to flush runtime journal from PID 1
[ 4.970624] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 4.970670] brcmfmac: power management disabled
[ 5.410746] tun: Universal TUN/TAP device driver, 1.6
[ 5.410755] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 6.029163] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:217084k SSFS
[ 6.067661] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.067839] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.245348] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 7.557880] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.558506] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 9.114220] uart-pl011 3f201000.serial: no DMA platform data
[ 13.169551] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 13.247422] nf_conntrack version 0.5.0 (15360 buckets, 61440 max)
[ 13.910679] brcmfmac: brcmf_cfg80211_stop_ap: setting INFRA mode failed -7
[ 166.749136] random: crng init done
