boomramada
Backup up pi Sd
Wed Dec 13, 2017 12:31 am
Hi I got a raspberry pi with 64gb Sd card, but actual used size is around 8gb. However when I back it up using image reader software, it's comes up to 64gb.
Is there is a way to creating a backed up image file with much less size. I want to move the os from 64 to 32 gb card.
n67
Re: Backup up pi Sd
Wed Dec 13, 2017 1:03 am
The standard answer to this question is: piclone
This is a GUI program that can be invoked either from the Terminal command line (as piclone) or via:
Menu -> Accessories -> SD Card Copier
It can be used on a "live" system - you can backup from the running system (on /dev/mmcblk0p?) to a fresh card in the USB card reader (/dev/sda)
"L'enfer, c'est les autres"
Epmu Sn!
wolbert
Re: Backup up pi Sd
Wed Dec 13, 2017 1:25 am
What he said. Piclone makes a file based copy. It is different from dd which makes byte for byte copy.
jcyr
Re: Backup up pi Sd
Wed Dec 13, 2017 1:59 am
I use these easy personal scripts to do exactly that using my laptop, or desktop PC:
https://github.com/jean-m-cyr/raspbiansd
It's um...uh...well it's kinda like...and it's got a bit of...
