cjan
kodi-rbp-17.6
Fri Dec 08, 2017 1:04 am
just a note, only Omxplayer video driver work, mmal not work.
Dycius
Re: kodi-rbp-17.6
Sat Dec 16, 2017 11:24 am
There are some codecs for which you need to buy a license, and put a key in /boot/config.txt. H.264 is included in the price of the RPi3, but not MPEG-2 (DVDs) or VC-1 (WMV), so even if you had MMAL or OpenMAX access, you'd need a license to h/w decode either of those two (viz, MPEG-2 or VC-1) formats.
Also, MMAL and OPenMAX do not work on 64-bit yet. Follow https://github.com/raspberrypi/firmware ... -190803961 for more info on that.
cjan
Re: kodi-rbp-17.6
Sat Dec 16, 2017 12:48 pm
raspbian kodi build didn't need license both drivers work.
cjan
Re: kodi-rbp-17.6
Sun Jan 14, 2018 10:01 pm
kodi-rbp got update build but worse, if switch to mmal driver kodi halted.
zuzaparany
Re: kodi-rbp-17.6
Mon Jan 15, 2018 5:27 pm
I just wrote a simple python program for omxplayer that scans my library and offer which movie to play. I gave up on kodi when it started to require 256 MB of ram. For a device such as rpi that has 1GB of ram that is a lot if you want to run other stuff as well. Basicly, it only adds some fancy gui and browse option plus addons for subtitles and stuff. I can live without that.
cjan
Re: kodi-rbp-17.6
Sun Jun 24, 2018 11:12 pm
18-a2 seems omx & mmal both work now.
Return to “Arch”
