shaikh
0-10v PWM
Wed Dec 06, 2017 4:49 pm
Hi all,
I need to control a fan via PWM from a raspberry pi.
The PWM on the fan states "PWM - 10V min". I assume this means it requires a 10v PWM signal. What is the best way to accomplish this using a pi as the GPIO pins will be 3.3v.
I have attached the information from the fan supplier in which it states a 10v PWM is required.
scotty101
Re: 0-10v PWM
Wed Dec 06, 2017 5:00 pm
A transistor or optoisolator where the 'output side' is connected to 10v.
Or a logic level converter
Given the mains voltages involved, i'd go for the optoisolator option.
shaikh
Re: 0-10v PWM
Wed Dec 06, 2017 5:17 pm
Thanks for the reply.
I don't have any experience in optoisolators.
Am i correct in saying that the optoisolator will basically act as a switch, switching the 10V 5ma supply creating a 10v PWM .
scotty101
Re: 0-10v PWM
Wed Dec 06, 2017 5:26 pm
Essentially yes. The 3.3v output from a GPIO pin is passed in to the optoisolator powering an LED, this LED triggers a light sensitive transistor allowing current to flow through it. Treat it like a transistor.
shaikh
Re: 0-10v PWM
Wed Dec 06, 2017 5:28 pm
Will this be able to cope with the 1 - 10kHz PWM frequencies?
Would this also be the case with a transistor? Would they cope with the PWM frequencies.
scotty101
Re: 0-10v PWM
Wed Dec 06, 2017 5:56 pm
Probably. You'd need to check with the specific datasheet to confirm. 10KHz isn't that fast.
Re: 0-10v PWM
Wed Dec 06, 2017 7:14 pm
Pretty much any optoisolator will cope with 10KHz. I've just checked a few datasheets on common types and they can all handle it.
