troysie
Python code for flow meter
Wed Dec 06, 2017 3:17 pm
I am using the following python code for a flow meter.
[codeimport RPi.GPIO as GPIO
import time, sys
GPIO.setmode(GPIO.BOARD)
inpt = 11
GPIO.setup(inpt,GPIO.IN)
rate_cnt = 0
tot_cnt = 0
minutes = 0
constant = 0.10
time_new = 0.0
print('Water Flow - Approximate')
print('Control c to exit')
while True:
time_new = time.time() + 60
rate_cnt = 0
while time.time() <= time_new:
if GPIO.input(inpt)!= 0:
rate_cnt += 1
tot_cnt += 1
try:
print(GPIO.input(inpt), end='')
except KeyboardInterrupt:
print('\nCTRL C - Exiting nicely')
GPIO.cleanup()
sys.exit()
minutes += 1
print('\nLiters / min',round(rate_cnt * constant,4))
print('Total liters', round(tot_cnt * constant,4))
print('Time (min & clock) ', minutes, '\t', time.asctime(time.localtime()))
GPIO.cleanup()
print('Done')][/code]
The problem is it keeps running when the flow stops. When the flow stops it stops on either 0 or 1. If it stops on zero it stops recording, but if it stops on 1 it keeps recording. Can I alter the program to stop when the flow stops and start when the flow starts
I am a beginner at python and finding it quite difficult. Any help would be much appreciated
Regards Troysie
scruss
Re: Python code for flow meter
Wed Dec 06, 2017 3:49 pm
I think your paste went a bit wrong:
import time, sys
inpt = 11
rate_cnt = 0
tot_cnt = 0
minutes = 0
constant = 0.10
time_new = 0.0
while True:
    rate_cnt = 0
    while time.time() &lt;= time_new:
            rate_cnt += 1
            tot_cnt += 1
        try:
           GPIO.cleanup()
           sys.exit()
    minutes += 1
GPIO.cleanup()
print('Done')]
You might want to look at using a callback function that increments a counter every time a change of state is seen. RPi.GPIO's Interrupts and Edge detection is a little-too-brief introduction. Some potential code is here How to use the water flow sensor with raspberry?, but note the corrections given further down the same page.
troysie
Wed Dec 06, 2017 5:16 pm
I get invalid syntax on the following line, the semi colon is highlighted
Regards Troysie
rpdom
Wed Dec 06, 2017 5:45 pm
I suspect that is an HTML markup failure. The code should look like this
scruss
Thu Dec 07, 2017 12:30 am
yeah, I just pasted back your code from the Python source. Guess I didn't catch all the HTMLizing. I certainly didn't fix anything
troysie
Thu Dec 07, 2017 7:56 am
I have found this code on the internet that only operates when flow is detected. It returns sensor High or Low and time. I have tried this and it works. Can I incorporate into this code to record L/min and total volume.
 #!/usr/bin/python
#    ___  ___  _ ____
#   / _ \/ _ \(_) __/__  __ __
#  / , _/ ___/ /\ \/ _ \/ // /
# /_/|_/_/  /_/___/ .__/\_, /
#                /_/   /___/
#       Hall Effect Sensor
# This script tests the sensor on GPIO17.
# Author : Matt Hawkins
# Date   : 03/04/2017
# http://www.raspberrypi-spy.co.uk/
# Import required libraries
import time
import datetime
def sensorCallback(channel):
  # Called if sensor output changes
  timestamp = time.time()
  stamp = datetime.datetime.fromtimestamp(timestamp).strftime('%H:%M:%S')
  if GPIO.input(channel):
    # No magnet
    print("Sensor HIGH " + stamp)
  else:
    # Magnet
    print("Sensor LOW " + stamp)
def main():
  # Wrap main content in a try block so we can
  # catch the user pressing CTRL-C and run the
  # GPIO cleanup function. This will also prevent
  # the user seeing lots of unnecessary error
  # messages.
  try:
    # Loop until users quits with CTRL-C
    while True :
      time.sleep(0.1)
    # Reset GPIO settings
    GPIO.cleanup()
# Tell GPIO library to use GPIO references
GPIO.setmode(GPIO.BCM)
print("Setup GPIO pin as input on GPIO17")
# Set Switch GPIO as input
# Pull high by default
GPIO.setup(17 , GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.add_event_detect(17, GPIO.BOTH, callback=sensorCallback, bouncetime=200)
if __name__=="__main__":
   main()
Regards Troysie
Return to “Beginners”
Who is online
Users browsing this forum: No registered users and 39 guests
