troysie
Python code for flow meter
Wed Dec 06, 2017 3:17 pm
I am using the following python code for a flow meter.
[codeimport RPi.GPIO as GPIO
import time, sys
GPIO.setmode(GPIO.BOARD)
inpt = 11
GPIO.setup(inpt,GPIO.IN)
rate_cnt = 0
tot_cnt = 0
minutes = 0
constant = 0.10
time_new = 0.0
print('Water Flow - Approximate')
print('Control c to exit')
while True:
time_new = time.time() + 60
rate_cnt = 0
while time.time() <= time_new:
if GPIO.input(inpt)!= 0:
rate_cnt += 1
tot_cnt += 1
try:
print(GPIO.input(inpt), end='')
except KeyboardInterrupt:
print('\nCTRL C - Exiting nicely')
GPIO.cleanup()
sys.exit()
minutes += 1
print('\nLiters / min',round(rate_cnt * constant,4))
print('Total liters', round(tot_cnt * constant,4))
print('Time (min & clock) ', minutes, '\t', time.asctime(time.localtime()))
GPIO.cleanup()
print('Done')][/code]
The problem is it keeps running when the flow stops. When the flow stops it stops on either 0 or 1. If it stops on zero it stops recording, but if it stops on 1 it keeps recording. Can I alter the program to stop when the flow stops and start when the flow starts
I am a beginner at python and finding it quite difficult. Any help would be much appreciated
Regards Troysie
scruss
Re: Python code for flow meter
Wed Dec 06, 2017 3:49 pm
I think your paste went a bit wrong:
import time, sys
inpt = 11
rate_cnt = 0
tot_cnt = 0
minutes = 0
constant = 0.10
time_new = 0.0
while True:
    rate_cnt = 0
    while time.time() &lt;= time_new:
            rate_cnt += 1
            tot_cnt += 1
        try:
           GPIO.cleanup()
           sys.exit()
    minutes += 1
GPIO.cleanup()
print('Done')]
You might want to look at using a callback function that increments a counter every time a change of state is seen. RPi.GPIO's Interrupts and Edge detection is a little-too-brief introduction. Some potential code is here How to use the water flow sensor with raspberry?, but note the corrections given further down the same page.
Pronouns: he/him
troysie
Wed Dec 06, 2017 5:16 pm
I get invalid syntax on the following line, the semi colon is highlighted
Regards Troysie
Wed Dec 06, 2017 5:45 pm
I suspect that is an HTML markup failure. The code should look like this
scruss
Thu Dec 07, 2017 12:30 am
yeah, I just pasted back your code from the Python source. Guess I didn't catch all the HTMLizing. I certainly didn't fix anything
Pronouns: he/him
troysie
Thu Dec 07, 2017 7:56 am
I have found this code on the internet that only operates when flow is detected. It returns sensor High or Low and time. I have tried this and it works. Can I incorporate into this code to record L/min and total volume.
 #!/usr/bin/python
#    ___  ___  _ ____
#   / _ \/ _ \(_) __/__  __ __
#  / , _/ ___/ /\ \/ _ \/ // /
# /_/|_/_/  /_/___/ .__/\_, /
#                /_/   /___/
#       Hall Effect Sensor
# This script tests the sensor on GPIO17.
# Author : Matt Hawkins
# Date   : 03/04/2017
# http://www.raspberrypi-spy.co.uk/
# Import required libraries
import time
import datetime
def sensorCallback(channel):
  # Called if sensor output changes
  timestamp = time.time()
  stamp = datetime.datetime.fromtimestamp(timestamp).strftime('%H:%M:%S')
  if GPIO.input(channel):
    # No magnet
    print("Sensor HIGH " + stamp)
  else:
    # Magnet
    print("Sensor LOW " + stamp)
def main():
  # Wrap main content in a try block so we can
  # catch the user pressing CTRL-C and run the
  # GPIO cleanup function. This will also prevent
  # the user seeing lots of unnecessary error
  # messages.
  try:
    # Loop until users quits with CTRL-C
    while True :
      time.sleep(0.1)
    # Reset GPIO settings
    GPIO.cleanup()
# Tell GPIO library to use GPIO references
GPIO.setmode(GPIO.BCM)
print("Setup GPIO pin as input on GPIO17")
# Set Switch GPIO as input
# Pull high by default
GPIO.setup(17 , GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.add_event_detect(17, GPIO.BOTH, callback=sensorCallback, bouncetime=200)
if __name__=="__main__":
   main()
Regards Troysie
