Taxicletter
Raspbian doesn't boot after upgrade to Stretch [solved]
Mon Dec 04, 2017 4:40 pm
I tried to upgrade from Jessie to Stretch. After some trouble, it did seem like it worked.
But when I boot, I get the raspberries and the splash screen and the info lines about checking stuff. But then it hangs with a black screen.
No cursor or anything.
Can I start in some rescue mode? How do I do that?
(I know this way of upgrading is not recommended)
Thanks & regards,
Jonathan
--::--::- 3 x Raspberry Pi 3 - Raspbian Lite 9 - RuneAudio - one broke (wifi) - not in use -::--::--
wh7qq
Re: Raspbian doesn't boot after upgrade to Stretch
Wed Dec 06, 2017 8:09 pm
You did not state how you upgraded but from the context, I guess you did a
sudo apt-get dist-upgrade
trying to preserve your saved files.
First, did you do a
sudo apt-get  update
before the dist-upgrade? That is crucial to get your flie list up to the latest Jessie and it is a good idea at that point to do a
sudo apt-get upgrade
so that you at least have the latest Jessie before doing the big step to Stretch. What you wind up with is a mismatch of dependencies and new stuff and a lot of problems seem to result.
Best thing would be to load your current uSD card in a reader on a separate PC and save all your necessary files. Then, download Raspbian-latest, verify the sha256sum and use Etcher to burn the new .zip file to the uSD card. Then load your important files back to the uSD card, or even better, wait until you get the new OS reconfigured before reloading your important files. Delete all Jessie configuration files because some/many will not work or might even screw things up on Stretch.
I think the only rescue mode available is in Noobs but I don't use it so I don't know for sure. I have heard that from Noobs, you can hold down the shift key during boot but this does not work with Raspbian.
Taxicletter
Mon Jan 15, 2018 7:45 pm
No, I first changed the repositories to Stretch.
I reinstalled everything already :-)
Thanks for your reply!
