georgelza
Display-o-tron HAT projects
Sun Dec 03, 2017 4:49 pm
Hi all
ok, must be me, but once you have installed the display-o-tron HAT, what else can you do with your RPI.
I have a RPi Zero W with some temperature (DHT22's) and a BMP280 connected, and won't mind connecting the Display-o-tron also, but it expects to be pushed onto the entire set of pin outs.
Looking at the Display-o-tron it looks like it has some GPIO pins I can work with...5... I'm guessing I soldier some pins in there and then recode scripts to access the DHT22's and BMP280 via them. (although I see some pins labelled SDA and SCL), might be option to use them for BMP280 ?
G
georgelza
Re: Display-o-tron HAT projects
Fri Jun 14, 2019 5:58 pm
anyone ?
G
pcmanbob
Fri Jun 14, 2019 10:52 pm
If you look at this web site https://pinout.xyz/pinout/display_o_tron_hat#
it will show you which pins it is using, Yes you will need to solder your own pins to the board for the gpio breakout.
As for what projects you can do with it I guess that's down to your interests and imagination.
echmain
Sat Jun 15, 2019 2:40 am
Gotta give you a tip of the hat for your patience.
georgelza
Sat Jun 15, 2019 1:57 pm
hehehe
even at times I amaze myself :D
G
alphanumeric
Sun Jun 16, 2019 10:41 am
Another way to do it is to mount a Proto Hat on a stacking header between your Pi and displayatron hat.
https://www.adafruit.com/product/2310
https://www.adafruit.com/product/1979
This will give you fairly easy access to almost all of the GPIO pins.
It will also help lessen the heat transfer from the Pi to the BME280 on the displayatron.
georgelza
Sun Jun 16, 2019 11:04 am
At the moment I got the DOT plugged onto ZeroW and then configured a DHT11 (to be replaced by a BME280) on the top pin's.
Trying to decide how I'm going to package this nicer...
Might opt for a different LCD, need 3 or 4 lines, preferable form factor of a Zero W.
For now it's working.
Assume with that stacking board I'll only then wire over the used pin's from the Pi to the DOT, as the DOT have a 42pin female receiver.
G
alphanumeric
Sun Jun 16, 2019 11:52 am
if you solder the stacking header to the Proto Hat instead of the one that comes with it, and solder the stacking header on the right way. ;)
The Proto Hat plugs into the Pi just like any other hat. Female header on the Proto hat to male GPIO pins on the Pi. Then you just plug the DOT on top the Proto Hat. You'll need tall standoffs to mount the Proto hat to the Pi.
https://www.adafruit.com/product/2337
Here is what I did with my Proto Hats and my Sense Hat. Two weather clocks.
Its a link to my public onedrive folder with my build pictures
https://1drv.ms/f/s!AjOYwiwlwDtpgq8_0VrdS3_H5xL_AA
georgelza
Wed Jun 19, 2019 2:38 pm
... anyone seen before.
line 0, first characters printed ":17:"
always a colon, followed by 2 numbers and another colon.\\does not matter what i do.
  	Hum_String  = "Humidity: "+ humid+" %" #define string for display-o-tron
	Temp_String = "Temp: "+ cT+ " C"
	Time_String = date_time
	lcd.clear() #clear display-o-tron
	# display data on display-o-tron
	lcd.set_cursor_position(0,1)
	lcd.write(Hum_String)
	lcd.set_cursor_position(0,0)
	lcd.write(Temp_String)
	lcd.set_cursor_position(0,2)
	lcd.write(Time_String)
scotty101
Wed Jun 19, 2019 8:33 pm
Can you share a more complete code example? What sets humid for example?
I suspect you aren't converting humid to a string but it is impossible to tell with the partial example that you've shared.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
georgelza
Thu Jun 20, 2019 5:22 am
#!/usr/bin/python
#   File            :   dp.py
#   Created     	:   15th June 2019
#   Notes       	:   https://iotbytes.wordpress.com/store-mqtt-data-from-sensors-into-sql-database/
#					:	https://pythontic.com/database/influxdb/writing_and_querying
#					:	https://www.raspberrypi.org/forums/viewtopic.php?t=197513
#					:	https://pinout.xyz/pinout/display_o_tron_hat
from influxdb import InfluxDBClient
import json
from time import sleep
from datetime import datetime
import dothat.backlight as backlight
import dothat.lcd as lcd
import dothat.touch as touch
import RPi.GPIO as GPIO
import dht11
# initialize GPIO
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
dtime 				= 30   		# seconds between measurements (n-1)
LED_enabled 		= True		# Is the LED + Backlight enabled/disabled
Hum_String  		= ""
Temp_String 		= ""
Time_String 		= ""
Temperature_Value 	= 0
Humidity_Value    	= 0
humval            	= 0
# DHT Settings
# Set GPIO sensor is connected to
gpio=19
# read data using Pin GPIO19
instance = dht11.DHT11(pin=gpio)
# InfluxDB Settings
user        	= 'winewine'
password    	= '....'
dbname      	= 'under_the_stairs'
dbuser      	= 'winewine'
dbuser_password = '.....'
host			= 'localhost'
port			= 8086
# DOT Settings
@touch.on(touch.LEFT)
def handle_left(channel, event):
	global LED_enabled
	LED_enabled = False
	print("Toggle Backlight Mode OFF!!!")
	lcd.clear()  			# clear display-o-tron
	backlight.off()
@touch.on(touch.RIGHT)
def handle_right(channel, event):
	global LED_enabled
	LED_enabled = True
	print("Toggle Backlight Mode ON!!!")
	# Color indicator for Temperature
	if (Temperature_Value < 18):
		backlight.hue(0.5)  # blue bellow 18C
	elif (Temperature_Value > 24):
		backlight.hue(1)  # red above 23C
	else:
		backlight.hue(0.2)  # green from 18 to 24C
	# display humidity on bargraph (1 led per 16.7% humidity)
	backlight.set_graph(humval)
	lcd.set_cursor_position(0, 1)
	lcd.set_cursor_position(0, 0)
	lcd.set_cursor_position(0, 2)
"""Instantiate a connection to the InfluxDB."""
try:
	print("Host : {0}".format(host))
	print("Port : {0}".format(port))
	print('Connecting to InfluxDB": {0}'.format( str(datetime.now().strftime("%Y-%m-%d %H:%M:%S.%f"))) )
	client = InfluxDBClient(host, port, user, password, dbname)
	print("Switch user : " + dbuser)
	client.switch_user(dbuser, dbuser_password)
except Exception as err:
	print( 'Connection Failed !!!": {time}, {err}'.format(
		time=str(datetime.now().strftime("%Y-%m-%d %H:%M:%S.%f")), err=str(err)))
	break
while True:
	global Hum_String
	global Temp_String
	global Time_String
	global Temperature_Value
	global Humidity_Value
	global humval
	result 			= instance.read()
	temperature 	= result.temperature
	humidity    	= result.humidity
	Temperature_Value 	= float("{0:.2f}".format( temperature ))
	Humidity_Value 		= float("{0:.2f}".format( humidity ))
	#get time
	date_time = (datetime.today().strftime("%Y-%m-%dT%H:%M:%S"))
	# Output data to screen
 	humid = str(float ("%3.f" % humidity)) #define output formats for Humidity and Temperature
	cT = str(float ("%3.f" % temperature))
	humval = (abs(humidity)/100)
	# Output data to display-o-tron
	# Build JSON Payload that will be inserted into InfluxDB via Node-Red integration localhost:1880
	Data = [{
		"measurement":"wine_cellar",
     	"tags": {
       		"user"  	: "winewine",
   			"sensor"	: "red-1"
   		"fields":{
       		"temperature": Temperature_Value,
         	"humidity"   : Humidity_Value
	if Temperature_Value > 0 and Humidity_Value > 0 :
		if LED_enabled:
				backlight.hue(0.5) #blue bellow 18C
				backlight.hue (1) # red above 23C
			else:
		try:
			print("Write points: {0} : {1}".format(date_time, Data))
			client.write_points(Data)
			print( 'Write Failed !!!": {time}, {err}'.format(
	print ('Press Ctrl+C to quit.\n')
	try:
		sleep(dtime)
	except KeyboardInterrupt:
		# When Ctrl+C is pressed execution of the while loop is stopped
		print('Exit on request')
		break
print ("measurement circle done")
lcd.clear
backlight.off()
pcmanbob
Thu Jun 20, 2019 7:13 am
You need to edit your code post and use code tags, rather than quote tags to preserve the indentation.
davidcoton
Thu Jun 20, 2019 7:17 am
You need to edit your code post and use edit [code] [/code] tags, rather than quote tags to preserve the indentation.
FTFY
Signature retired
georgelza
Thu Jun 20, 2019 7:19 am
sorry, was a typo... or make that clickoooo
G
scotty101
Thu Jun 20, 2019 7:36 am
Try changing the line
to
humid = str(float ("%3.f" % Humidity_Value)) #define output formats for Humidity and Temperature
You seem to be doing a lot of unnecessary conversions between floats and string and then back again.
For example
Why do you convert the humidity to a string to then convert it to a float and then back in to a string.
I'd suggest getting rid of all of these and only converting/formatting the humidity/temperature values at the point that you format the string.
Also you are using 3 different methods to format a string
May I suggest that you move to use just the .format method as this is the most modern (aside from f-strings)
pcmanbob
Thu Jun 20, 2019 7:44 am
So let me get this straight you say your display shows this
Humidity: 23:
were as you were expecting this
Humidity: 23 %
when trying to solve problems like this its always good to print the string to the terminal screen so you can see what your string actually contains
try adding
  	print (Hum_String)
as a first step , if you printed line looks correct then try writing a simple test program to display the humidity information one bit at a time to see if its displays each part correctly.
georgelza
Thu Jun 20, 2019 8:09 am
I'm, saying I'm getting actualllyyyyy
%17%imidity 45 %
and the number 17 changes here and there a bit...
G
georgelza
Thu Jun 20, 2019 8:10 am
will improve, allot of this was me=lazy and just copy paste and it worked, showed what i wanted, ye i should probably have gone through it, but was sick, on meds and it showed me what i wanted.
G
to
For example
georgelza
Sat Jun 22, 2019 10:03 am
Photo of LCD...
IMG_6875 copy.jpg (194.59 KiB) Viewed 706 times
pcmanbob
Sat Jun 22, 2019 10:19 am
To me that looks like your last line is to long for the display so the last part of it is auto wrapping on to the next line which happens to be the first line of the display.
try printing the line you want to put on the LCD on your pi screen and count the number of characters including spaces.
I think you will find it is 19 which you can't display on a 16X3 LCD as it only has 16 character spaces per line.
georgelza
Sat Jun 22, 2019 10:38 am
thanks, will try.
G
georgelza
Sat Jun 22, 2019 3:04 pm
spot on, was not aware of the if last line to long then it wraps to first line,
that was the problem, I removed the second and micro seconds from display, not really needed, and all pretty now. Thanks.
G
alphanumeric
Sat Jun 22, 2019 7:22 pm
I ditched the seconds in my message too. I don't bother displaying the year either. Just personal choice is all.
I use
 dateString = "%A %B %-d %-I:%M:%p"
My message is displayed as, It is Saturday June 22 4:13:PM, as an example. Mine is a scrolling message so how long it is doesn't really matter
http://strftime.org/
I also round off my Temperature Humidity and Pressure readings. Nothing after the decimal is displayed. It ended up being easier for others to read on the fly.
georgelza
Sun Jun 23, 2019 5:17 am
Hmm
Think I need to go dig around scrolling a bit 😜
G
alphanumeric
Sun Jun 23, 2019 8:59 am
I don't really have much choice but to scroll my message. The Sense Hat matrix is only 8x8. If I want readable text, scrolling is the way to go. On the plus side they made it really easy to do, and the LED's are RGB My messages change color based on the readings. Temperatures below 0c for example are displayed in Blue. Temps above 30c Red etc.
Anyway, that Display o tron looks like a nice bit of kit so have fun. :D
