laziegoblin wrote: ↑Sun Dec 03, 2017 12:49 pm
PS: The power supply is high enough, the mouse and keyboard both use 100mA so nothing that should be an issue in that regard. Tried plugging them into different USB ports. HDMI and Ethernet connection work fine.
How do you know "The power supply is high enough," have you load tested it?
If Ethernet is working, then the USB ports should be working as well (they are all connected to the same internal hub).
This really sounds like a power problem to me. Exactly what are you using for a power supply, and how is it connected to the Pi3. Note that many phone chargers have poor voltage regulation, because battery charging does not require a precise 5V power delivery (your phone will charge at 4.5V, but that won't run a Raspberry Pi3). Another common source of power loss is through the micro-USB cable delivering the power. Many standard micro-USB cables have thin wires with too much resistance to deliver the kind of power a Pi3 might demand (they are only required to deliver 500mA, per the USB 2.0 spec, but the Pi3 can demand more than 4 times that when fully loaded).
wh7qq wrote: ↑Sun Dec 03, 2017 7:16 pm
I like SanDisk Ultra from Amazon but others like Samsung are good too. Do not go for bargains here...your time is worth more than the savings. Counterfeits abound.
Ironically, Sandisk and Samsung are probably the most commonly counterfeited cards. I use mostly Samsung EVO+ (EVO Plus) series cards now, because I have found them to be faster on the Pi than pretty much any other card (including cards with higher prices and speed ratings).
Try a Raspbian image instead of NOOBS.
- Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
- Grab the Etcher software from https://etcher.io/
- Install Etcher and use it to write the Raspbian image to your SD card. You don't need to extract the image or format the card prior to writing. Just choose the Raspbian .zip, pick your SD card and write (if you have trouble, verify the SHA256 checksum of the download).
- Remove and reinsert the SD card so that your Windows or Mac PC can see the small FAT32 partition on the SD card.
- On that small partition, create a file with the name ssh (or ssh.txt). It can be empty, the contents don't matter.
- If you are connecting the Pi to your router with an Ethernet cable, then you can eject the card and use it to boot your Pi now.
- To connect to a wireless network, create another file on the card called wpa_supplicant.conf, which has the following inside:
update_config=1
country=US
network={
ssid="Your network name/SSID"
psk="Your WPA/WPA2 security key"
key_mgmt=WPA-PSK
Edit country=, ssid= and psk= with your information and save the file.
- Safely eject the card from your PC and use it to boot the Pi.
If Raspbian finds an ssh file it will enable SSH and delete the file. If it finds a wpa_supplicant.conf file, it will move it to its correct location and connect to your wireless network. If you have installed iTunes or Bonjour you should be able to connect using raspberrypi.local instead of the Pi's IP address. However, if you have more than one Raspberry Pi on your network, and you have not changed the default hostnames, then you'll probably need to use the IP address.
To get your Pi's IP address, login to your router and look for raspberrypi in the list of connected clients. Or you could use a network scanner app, like Fing for your phone, which will scan your network and list all connected devices. If you have an ASUS router they have their own phone app.
Fing app:
https://play.google.com/store/apps/deta ... fing&hl=en
ASUS Router app:
https://play.google.com/store/apps/deta ... home&hl=en
Both of these should also be available for iPhone.
To login using SSH from Windows, you'll need the PuTTY app, which looks like this.
In the Host Name (or IP address) field, enter either,
pi@raspberrypi.local
or
pi@{your Pi's IP address}
make sure SSH is selected (it should be by default) and click on Open.
If you have done everything correctly, a terminal window will open and you should see a password request. Although, if it's the first time you've connected to your Pi, you may have to answer "yes" to a security question, and then you'll get the password prompt. You'll also get a warning about having SSH enabled with the default password, so type passwd[Enter] and enter a new password (twice).
If you can connect to your Pi with SSH, then it booted correctly and is working.
Enter the command:
And if there were no errors, enter:
which will install any updates to Raspbian. Reboot when that finishes and hopefully whatever problems you were having will be fixed.
