yoavz
Case from RS does not allow proper HDMI connection
Sat Oct 13, 2012 12:32 pm
I just received my RS-components raspberry-pi and cases.
Now the problem is that the HDMI connecter can't connect all the way...
Due to that there's no signal.
Once you remove the upper part of the case you can connect the HDMI connector fully and get a video signal.
Any idea about what to do or should I just grab my Dremel and fix it the old fashioned way?
Thank you,
Yoav.
thogue
Re: Case from RS does not allow proper HDMI connection
Sat Oct 13, 2012 2:30 pm
Sounds like a fix the old fashion way, also all hdmi cables are not created equal.
abishur
Sat Oct 13, 2012 2:58 pm
+1 to the your cable might be a little too thick when compared to other HDMI cables, my solution would be to the "old fashioned" one :lol:
Dear forum: Play nice ;-)
yoavz
Sat Oct 13, 2012 9:06 pm
I just "old fashioned" my RS raspberrypi case :)
2 minutes with my Dremel and some dentist-like-noise and now the case is usable...
At first I thought that my R-Pi broke...
