I'm having some trouble changing how long lights are on/off for within a loop. I'm using one of the standard 8 relay boards to do this. What I currently have is 2 buttons (momentary push buttons) that increase/decrease the delay times between the lights turning on/off and 1 button that starts the on/off sequence. The specific problem I am having is that the button inputs do not have a real-time affect on the delay times. For example, if the loop is programmed to start with 4 second delays between the on/off switching and the increase button is held down it will only affect the delay time when the loop is complete and repeats. If i just press one of the input buttons momentarily there is no change in the delay time at all.
I'm looking for a way to instantaneously change this before the loop has finished executing without restarting the loop and losing the current position of the light cycle. Say for example I have 8 lights in a horizontal line programmed to turn off/on going from left - right every 2 seconds until the eighth light is reached and then the cycle reverses. I would like to be able to change the delay time between the lights on the fly without the whole "cycle" restarting.
I have looked into interrupts / multi-threading, but I'm not sure if it's the correct course of action.
If you could suggest some solutions, I would be very grateful.
Any help would be greatly appreciated! Thanks !
Here's my current code:
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(2, GPIO.OUT) # relay 1
GPIO.setup(3, GPIO.OUT) # relay 2
GPIO.setup(4, GPIO.OUT) # relay 3
GPIO.setup(17, GPIO.OUT) # relay 4
GPIO.setup(22, GPIO.OUT) # relay 5
GPIO.setup(10, GPIO.OUT) # relay 6
GPIO.setup(9, GPIO.OUT) # relay 7
GPIO.setup(11, GPIO.OUT) # relay 8
GPIO.output(2, GPIO.HIGH)
GPIO.output(3, GPIO.HIGH)
GPIO.output(4, GPIO.HIGH)
GPIO.output(17, GPIO.HIGH)
GPIO.output(22, GPIO.HIGH)
GPIO.output(10, GPIO.HIGH)
GPIO.output(9, GPIO.HIGH)
GPIO.output(11, GPIO.HIGH)
start_button= 14
decrease_button=23
increase_button = 25
GPIO.setup(start_button,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.setup(increase_button,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.setup(decrease_button,GPIO.IN,pull_up_down=GPIO.PUD_UP)
while(1):
while GPIO.input(start_button) == 0:
time1 = 1
while(1):
print "initiating sequence:"
#time.sleep(time1)
print time1
GPIO.output(2, GPIO.LOW)
GPIO.output(3, GPIO.LOW)
time.sleep(time1)
time.sleep(time1)
if GPIO.input(decrease_button) == 0:
time1+=.5
print "speed decreased by 1 second"
print time1
#time.sleep(1)
if GPIO.input(increase_button) == 0:
time1-=.5
print "speed increased by 1 second"
print time1
#time.sleep(1)
