AhmedOhlin
mouse and keyboard don't work with hub usb 3.0 on Raspberry
Tue Nov 28, 2017 2:54 pm
Hi all,
i need help from the Profis. I bought USB 3.0 hub for my raspberry pi 3. The mouse and the keyboard do not work when i connect them via usb hub to PI
i tried the same thing in Windows on my laptop. it works yithout problems.
i read in some website that the problem is not in the hub but it is in Linux but as i have seen on the webaite that the posts are really old. and i want to ask here may be there is an update for fixing this problem
device not accepting address 25, error -71raspberrypi new low-speed USB device number 26 using dwc_otg
markatlnk
Re: mouse and keyboard don't work with hub usb 3.0 on Raspberry
Tue Nov 28, 2017 4:22 pm
Old problem with USB 3 hubs. If you plug a USB 2 hub into the USB 3 hub, then that will work. Sorry it isn't a nice solution. But the USB 1.x slow devices such as keyboards and mice somehow don't register when plugged into a USB 3 hub on a pi.
Mark
HawaiianPi
Wed Nov 29, 2017 1:19 am
i read in some website that the problem is not in the hub but it is in Linux...
Actually, the problem is with the hub. Some USB 3.0 hubs are not true USB hub devices and require additional drivers. It's best to stick with USB 2.0 hubs with the Raspberry Pi, as some USB 3.0 hubs can behave very poorly on the Pi.
I have one USB 3.0 hub that works fine, and another that not only doesn't work, it also disables the Pi's built-in USB ports when I try to use it, which forces me to pull the power to reboot, as I have no keyboard or mouse control, and disconnecting the hub does not restore function to the Pi's USB ports, and even SSH logins fail. However, that rather nasty failing one works fine on my Windows 10 PC.
The USB 3.0 hub fiasco reminds me of the old WinModem days. :(
Winmodem is a generic term for a modem that uses software in place of hardware for certain functions. In technical terms, winmodems lack an instruction processing chip called a controller; winmodems are also referred to as controllerless modems or host-based modems.
It now appears that some USB 3.0 hubs are "WinHubs" which lack the hardware needed to be a true hub.
