Permission denied (publickey)I plugged the Pi's SD card into my Linux laptop and inspected the authorized_keys file and ensure all key entries are correct, which they are.
I SSHed to the Pi verbosely:
ssh -v -p 29922 jimjamz@192.168.0.5 -i ~/.ssh/my-keyfile
OpenSSH_6.7p1 Debian-5+deb8u3, OpenSSL 1.0.1t 3 May 2016
debug1: Reading configuration data /home/jimjamz/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 192.168.0.5 [192.168.0.5] port 29922.
debug1: Connection established.
debug1: identity file /home/jimjamz/.ssh/my-keyfile type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/jimjamz/.ssh/my-keyfile-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u3
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4p1 Raspbian-10+deb9u1
debug1: match: OpenSSH_7.4p1 Raspbian-10+deb9u1 pat OpenSSH* compat 0x04000000
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr umac-64-etm@openssh.com none
debug1: kex: client->server aes128-ctr umac-64-etm@openssh.com none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 22:90:11:f1:79:0f:7c:22:37:75:90:f0:23:97:f4:0f
debug1: Host '[192.168.0.5]:29922' is known and matches the ECDSA host key.
debug1: Found key in /home/jimjamz/.ssh/known_hosts:1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/jimjamz/.ssh/my-keyfile
debug1: No more authentication methods to try.
Permission denied (publickey).
As a test, I changed the sshd_config file by plugging the SD into my laptop and changing PasswordAuthentication to yes. When I tried to connecting to the Pi again, I could see it was now asking for a password, so I can see at least the changes I make to the SD via my laptop are being persisted when plugged into the Pi.
I also managed to take a copy of the /var/log/auth.log from the SD card after my attempts to SSH onto the Pi:
Nov 26 12:16:01 FLORENCE-PI CRON[1506]: pam_unix(cron:session): session closed for user jimjamz
Nov 26 12:17:01 FLORENCE-PI CRON[1516]: pam_unix(cron:session): session opened for user jimjamz by (uid=0)
Nov 26 12:17:01 FLORENCE-PI CRON[1515]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 26 12:17:01 FLORENCE-PI CRON[1516]: pam_unix(cron:session): session closed for user jimjamz
Nov 26 12:17:01 FLORENCE-PI CRON[1515]: pam_unix(cron:session): session closed for user root
Nov 26 12:18:01 FLORENCE-PI CRON[1558]: pam_unix(cron:session): session opened for user jimjamz by (uid=0)
Nov 26 12:18:01 FLORENCE-PI CRON[1558]: pam_unix(cron:session): session closed for user jimjamz
Nov 26 12:19:01 FLORENCE-PI CRON[1567]: pam_unix(cron:session): session opened for user jimjamz by (uid=0)
Nov 26 12:19:02 FLORENCE-PI CRON[1567]: pam_unix(cron:session): session closed for user jimjamz
