cvh17
Power on a modem at boot
Thu Nov 23, 2017 8:31 pm
I have two modem HATs.
Unit A is one of these: https://www.itead.cc/wireless/gsm-gprs- ... -v2-0.html.
Unit B is one of these: https://www.waveshare.com/product/modul ... ss-hat.htm
Using both a Pi model B+ and a Pi Zero, I can successfully turn on Unit A at boot by the addition of these commands to /etc/rc.local:
echo 17 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio17/direction
echo 1 > /sys/class/gpio/gpio17/value
Unit B does not turn on automatically with these commands. Can anyone suggest a way of getting Unit B to turn on automatically, please?
sora03
Re: Power on a modem at boot
Fri Nov 24, 2017 10:09 am
have you tried using a python code. use the gpiozero they have lot of examples
https://gpiozero.readthedocs.io/
FLOSS enthusiast, Debian user (linux-libre)
cvh17
Fri Nov 24, 2017 2:42 pm
Thank you, I haven't heard of GPIO Zero, and will give that a try. I'll report back on success or otherwise.
cvh17
Fri Nov 24, 2017 3:12 pm
I've found the schematic for Unit B here: https://www.waveshare.com/w/upload/2/20 ... matic_.pdf. Looking at the section in the middle at the bottom (titled 'RPI GPIO'), it would appear that the power gpio is number 17, and so the code I have in /etc/rc.local should work (but doesn't) -- have I misunderstood the schematic? I've not dealt with gpio in the past.
sora03
Sat Nov 25, 2017 7:04 am
GPIO 17 on the schematics is the physical PIN number the command that you used in the first post refers to the Broadcom pin numbering (BCM17)
I did not know the power pin based on the schematics. a pin reference can be found at: pinout.xyz
Is there any documentation besides the schematics on your hardware board?
Who is online
Users browsing this forum: Baidu [Spider], mooblie and 31 guests
