Adepalma
Creating If Statement Based off Sensor Reading
Tue Nov 21, 2017 10:41 pm
For a school project I am trying to create an if statement off of a sensor reading. Ideally, I want to have a photocell resistor send data to the pi, and then based off of that read data, proceed with the if/else statements. Does anyone know what command I can use to set a value to the data collected by the photocell?
DirkS
Re: Creating If Statement Based off Sensor Reading
Wed Nov 22, 2017 2:23 pm
What language? What photocell?
Also post the code you already have.
sora03
Thu Nov 23, 2017 11:59 am
you should post the code you have to help you debug it. generally what you want to do is get sensor data then use conditional if/then/else statements if the sensor reading is at a certain value.
FLOSS enthusiast, Debian user (linux-libre)
B.Goode
Thu Nov 23, 2017 12:14 pm
If 'photocell' means a Light Dependent Resistor then the Raspberry Pi Foundation have a resource (tutorial) that explains clearly how to use one.
https://projects.raspberrypi.org/en/pro ... -computing
The CamJam EduKit #2 also contains a light dependent resistor, and the associated worksheet describes how to write python scripts to get a reading from it.
https://camjam.me/?page_id=623
alphanumeric
Thu Nov 23, 2017 2:03 pm
I'm doing something similar with an SI1145 light sensor. I snipped some of my python code. I'm using it to dim (sense.low_light = True) the LED matrix on my sense hat in low light conditions. A dark room for example. And switch it back to full bright (sense.low_light = False) in bright light conditions. Outside in the bright sun for example.
import SI1145.SI1145 as SI1145
uvs = SI1145.SI1145()
def readvis():
    vis = uvs.readVisible()
    if vis < 300:
    elif vis >= 300:
bensimmo
Thu Nov 23, 2017 6:18 pm
def readvis():
    if vis < 300:
    elif vis >= 300:
That's given me another idea to play with, I have the TCS3472 on an Envirophat so could play with something similar.
alphanumeric
Thu Nov 23, 2017 8:01 pm
I bought the SI1145 to read the UV index. Once I got that working I started using the visible light readings to do other things. Bonus. =)
PingoBags
Fri Nov 24, 2017 10:15 am
def readvis():
    if vis < 300:
    elif vis >= 300:
You could probably simplify that even more by removing the if/elif
 sense.low_light = uvs.readVisible() < 300
sense.low_light would still equal false if uvs.readVisible() was greater than 300, and true if it was less.
alphanumeric
Fri Nov 24, 2017 12:21 pm
Yeah, there was another line after that, that I didn't post. I just did a quick edit. I'm doing a bit more than what I posted, and it would have just confused things. I'm also changing the text color on my Sense Hat to all whit if the VIS is above 500. That line read
  elif vis >= 300 and vis < 500 and m == (0):
before I edited it. I'm also turning on or off a secondary indicator (10mm LED's)
bensimmo
Fri Nov 24, 2017 2:34 pm
You don't really need the
vis >= 300
part of it as thats implied from the previous if statement. *
It's nice to have it there for reading, but you need to change two parts of you alter the range so for errors it is best no to have it there.
*Also elif should be else otherwise it'll error.
alphanumeric
Fri Nov 24, 2017 2:53 pm
It all works, and no errors. I will have a look at what you mentioned though. I'm no python expert, and a lot of my code was trial and error getting it to work.
alphanumeric
Fri Nov 24, 2017 3:07 pm
Can I put an else: at the end with nothing under it?
I'm using an "and". If m = 1 I want nothing to happen?
 elif vis >= 500 and m == (0):
 else:
bensimmo
Fri Nov 24, 2017 3:16 pm
Sorry I forgot you are actually checking the condition (as you wouldn't need to normally for just the light check)
It'll be fine
didn't need the else..
As you were .. ;-)
(No expert myself :-))
But if/else if/elif/else is the basic start of python. So Adepalma just needs to go and do a starter on Python.
Perhaps the main website examples.
alphanumeric
Fri Nov 24, 2017 3:29 pm
Ok. Works for me.
Who is online
Users browsing this forum: k-pi, youkiddin and 30 guests
