matbos
Can't install any package
Thu Oct 11, 2012 3:59 pm
Whemn I try to install anything with apt-get i get an error:
root@raspberrypi:/home/pi# apt-get upgrade
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
root@raspberrypi:/home/pi# sudo dpkg --configure -a
Setting up libdbus-1-3:armhf (1.6.8-1) ...
Segmentation fault
dpkg: error processing libdbus-1-3:armhf (--configure):
 subprocess installed post-installation script returned error exit status 139
Setting up libuuid1:armhf (2.20.1-5.2) ...
Segmentation fault
dpkg: error processing libuuid1:armhf (--configure):
dpkg: dependency problems prevent configuration of libparted0debian1:armhf:
 libparted0debian1:armhf depends on libuuid1 (>= 2.16); however:
  Package libuuid1:armhf is not configured yet.
dpkg: error processing libparted0debian1:armhf (--configure):
 dependency problems - leaving unconfigured
Setting up libxslt1.1:armhf (1.1.26-14) ...
Segmentation fault
dpkg: error processing libxslt1.1:armhf (--configure):
Setting up libgtk-3-0:armhf (3.4.2-4) ...
Segmentation fault
dpkg: error processing libgtk-3-0:armhf (--configure):
dpkg: dependency problems prevent configuration of parted:
 parted depends on libparted0debian1 (>= 2.2-1); however:
  Package libparted0debian1:armhf is not configured yet.
 parted depends on libuuid1 (>= 2.16); however:
dpkg: error processing parted (--configure):
Setting up libtiff4:armhf (3.9.6-9) ...
Segmentation fault
dpkg: error processing libtiff4:armhf (--configure):
Setting up libmysqlclient18:armhf (5.5.24+dfsg-9) ...
Segmentation fault
dpkg: error processing libmysqlclient18:armhf (--configure):
Setting up libsdl-mixer1.2:armhf (1.2.12-3) ...
Segmentation fault
dpkg: error processing libsdl-mixer1.2:armhf (--configure):
dpkg: dependency problems prevent configuration of libblkid1:armhf:
 libblkid1:armhf depends on libuuid1 (>= 2.16); however:
dpkg: error processing libblkid1:armhf (--configure):
dpkg: dependency problems prevent configuration of libgtk-3-bin:
 libgtk-3-bin depends on libgtk-3-0 (>= 3.4.2-4); however:
  Package libgtk-3-0:armhf is not configured yet.
dpkg: error processing libgtk-3-bin (--configure):
Setting up libcroco3:armhf (0.6.6-1) ...
Segmentation fault
dpkg: error processing libcroco3:armhf (--configure):
Processing triggers for gconf2 ...
dpkg: dependency problems prevent configuration of python-pygame:
 python-pygame depends on libsdl-mixer1.2; however:
  Package libsdl-mixer1.2:armhf is not configured yet.
dpkg: error processing python-pygame (--configure):
Setting up binutils (2.22-7.1) ...
Segmentation fault
dpkg: error processing binutils (--configure):
Setting up libcap2:armhf (1:2.22-1.2) ...
Segmentation fault
dpkg: error processing libcap2:armhf (--configure):
dpkg: dependency problems prevent configuration of libgail-3-0:armhf:
 libgail-3-0:armhf depends on libgtk-3-0 (= 3.4.2-4); however:
dpkg: error processing libgail-3-0:armhf (--configure):
dpkg: dependency problems prevent configuration of libmount1:
 libmount1 depends on libblkid1 (>= 2.17.2); however:
  Package libblkid1:armhf is not configured yet.
dpkg: error processing libmount1 (--configure):
Errors were encountered while processing:
 libdbus-1-3:armhf
 libuuid1:armhf
 libxslt1.1:armhf
 libgtk-3-0:armhf
 parted
 libtiff4:armhf
 libblkid1:armhf
 libgtk-3-bin
 libcroco3:armhf
 python-pygame
 binutils
 libcap2:armhf
 libgail-3-0:armhf
 libmount1
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
18 not fully installed or removed.
Need to get 0 B/2,951 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Internal Error, No file name for libuuid1
notarat
Re: Can't install any package
Thu Oct 11, 2012 4:03 pm
Did you do an apt-get update first? Just wondering...
matbos
Thu Oct 11, 2012 4:21 pm
Yes...
root@raspberrypi:/home/pi# apt-get update
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://mirrordirector.raspbian.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
It always says: E: Internal Error, No file name for libuuid1
RaTTuS
Contact: Twitter YouTube
Thu Oct 11, 2012 4:23 pm
sudo apt-get clean
sudo apt-get install -fy
sudo dpkg -i /var/cache/apt/archives/*.deb
May work ... YMMV
Covfefe
matbos
Thu Oct 11, 2012 4:24 pm
And that happens when i try to install any package :(
root@raspberrypi:/home/pi# apt-get install  omxplayer
The following NEW packages will be installed:
  omxplayer
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 5,207 kB/8,157 kB of archives.
After this operation, 10.0 MB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian/ wheezy/main omxplayer armhf 0.2.1~git20120916~2612f1d7 [5,207 kB]
Fetched 5,207 kB in 41s (124 kB/s)
matbos
Thu Oct 11, 2012 4:32 pm
Yes i have allready tryed it before, but:
root@raspberrypi:/home/pi# sudo apt-get clean
root@raspberrypi:/home/pi# sudo apt-get install -fy
Need to get 2,951 kB of archives.
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gnome-themes-standard armhf 3.4.2-2 [2,951 kB]
Fetched 2,951 kB in 27s (108 kB/s)
root@raspberrypi:/home/pi# sudo dpkg -i /var/cache/apt/archives/*.deb
(Reading database ... 60192 files and directories currently installed.)
Preparing to replace gnome-themes-standard 3.4.2-2 (using .../gnome-themes-standard_3.4.2-2_armhf.deb) ...
Unpacking replacement gnome-themes-standard ...
dpkg: dependency problems prevent configuration of gnome-themes-standard:
 gnome-themes-standard depends on libgtk-3-0 (>= 3.3.14); however:
dpkg: error processing gnome-themes-standard (--install):
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
dpkg: error processing gnome-themes-standard (--configure):
 libdbus-1-3:armhf
 libuuid1:armhf
 libxslt1.1:armhf
 libgtk-3-0:armhf
 parted
 libtiff4:armhf
 libblkid1:armhf
 libgtk-3-bin
 libcroco3:armhf
 python-pygame
 binutils
 libcap2:armhf
 libgail-3-0:armhf
 libmount1
plugwash
Thu Oct 11, 2012 6:58 pm
Can you try issuing the following commands and post the results
sed -i 's/set -e/set -ev/' var/lib/dpkg/info/libuuid1:armhf.postinst
dpkg --configure -a
matbos
Fri Oct 12, 2012 6:48 am
sed: can't read var/lib/dpkg/info/libuuid1:armhf.postinst: No such file or directory
malakai
Fri Oct 12, 2012 7:52 am
Your running as root?
what image have you loaded?
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
matbos
Fri Oct 12, 2012 8:36 am
Yes i am running it as root and i have the latest raspbian image
plugwash
Fri Oct 12, 2012 10:38 am
Sorry I made a slight error in the commands I gave you. The fixed version is below.
sed -i 's/set -e/set -ev/' /var/lib/dpkg/info/libuuid1:armhf.postinst
dpkg --configure -a
Can you try them and post the results.
matbos
Fri Oct 12, 2012 1:51 pm
root@raspberrypi:/home/pi# sed -i 's/set -e/set -ev/' var/lib/dpkg/info/libuuid1:armhf.postinst
root@raspberrypi:/home/pi# sudo sed -i 's/set -e/set -ev/' var/lib/dpkg/info/libuuid1:armhf.postinst
root@raspberrypi:/home/pi# sed -i 's/set -e/set -ev/' /var/lib/dpkg/info/libuuid1:armhf.postinst
root@raspberrypi:/home/pi# dpkg --configure -a
Segmentation fault
ADDUSERCONF='/etc/adduser.conf'
if test -f $ADDUSERCONF; then
    FIRST_SYSTEM_UID=$(sed -n "s/^[[:space:]]*FIRST_SYSTEM_UID[[:space:]]*=[[:space:]]*[\"']\?\([^\"']*\)[\"']\?/\1/p" $ADDUSERCONF)
    LAST_SYSTEM_UID=$(sed -n "s/^[[:space:]]*LAST_SYSTEM_UID[[:space:]]*=[[:space:]]*[\"']\?\([^\"']*\)[\"']\?/\1/p" $ADDUSERCONF)
    FIRST_SYSTEM_GID=$(sed -n "s/^[[:space:]]*FIRST_SYSTEM_GID[[:space:]]*=[[:space:]]*[\"']\?\([^\"']*\)[\"']\?/\1/p" $ADDUSERCONF)
    LAST_SYSTEM_GID=$(sed -n "s/^[[:space:]]*LAST_SYSTEM_GID[[:space:]]*=[[:space:]]*[\"']\?\([^\"']*\)[\"']\?/\1/p" $ADDUSERCONF)
fi
if test -z "$FIRST_SYSTEM_UID"; then
    FIRST_SYSTEM_UID=100
fi
if test -z "$LAST_SYSTEM_UID"; then
    LAST_SYSTEM_UID=999
fi
if test -z "$FIRST_SYSTEM_GID"; then
    FIRST_SYSTEM_GID=100
fi
if test -z "$LAST_SYSTEM_GID"; then
    LAST_SYSTEM_GID=999
fi
if ! getent group | grep -q libuuid; then
  groupadd -f -K GID_MIN=$FIRST_SYSTEM_GID -K GID_MAX=$LAST_SYSTEM_GID libuuid
fi
if ! getent passwd | grep -q libuuid; then
   useradd -d /var/lib/libuuid -K UID_MIN=$FIRST_SYSTEM_UID -K UID_MAX=$LAST_SYSTEM_UID -g libuuid libuuid
fi
mkdir -p /var/lib/libuuid
chown libuuid:libuuid /var/lib/libuuid
chmod 2775 /var/lib/libuuid
# Automatically added by dh_makeshlibs
if [ "$1" = "configure" ]; then
	ldconfig
fi
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
 libdbus-1-3:armhf
 libuuid1:armhf
 libxslt1.1:armhf
 libgtk-3-0:armhf
 parted
 libtiff4:armhf
 libblkid1:armhf
 libgtk-3-bin
 libcroco3:armhf
 python-pygame
 binutils
 libcap2:armhf
 libgail-3-0:armhf
 libmount1
Segmentation fault
fi
fi
    LAST_SYSTEM_UID=999
fi
fi
    LAST_SYSTEM_GID=999
fi
fi
fi
	ldconfig
fi
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
 libdbus-1-3:armhf
 libuuid1:armhf
 libxslt1.1:armhf
 libgtk-3-0:armhf
 parted
 libtiff4:armhf
 libblkid1:armhf
 libgtk-3-bin
 libcroco3:armhf
 python-pygame
 binutils
 libcap2:armhf
 libgail-3-0:armhf
 libmount1
Still the same :(
plugwash
Fri Oct 12, 2012 2:33 pm
ok now try
wget http://archive.raspbian.org/raspbian/po ... _armhf.deb
dpkg -i libc-bin_2.13-35_armhf.deb
dpkg --configure -a
matbos
Fri Oct 12, 2012 6:46 pm
Thanks man that worked :)
Minor_Miner
Sun Oct 21, 2012 5:00 pm
I'm having the same problems as the person above me, and tried the fix above. On the second line, it gave me this:
pi@raspberrypi ~ $ dpkg -i libc-bin_2.13-35_armhf.deb
dpkg: error: requested operation requires superuser privilege
pi@raspberrypi ~ $ sudo dpkg -i libc-bin_2.13-35_armhf.deb
dpkg: error: parsing file '/var/lib/dpkg/updates/0056' near line 0:
 EOF after field name `'
I've also had several SD card corruptions recently, it does it constantly, but it appears to be okay at the moment.
Any help for this linux n00b would be greatly appreciated.
plugwash
Mon Oct 22, 2012 3:52 pm
Try removing /var/lib/dpkg/updates/0056 and trying again
Minor_Miner
Tue Oct 23, 2012 10:25 pm
plugwash wrote:Try removing /var/lib/dpkg/updates/0056 and trying again
I tried doing that with the file browser, and it wouldn't let me, saying "permission denied".
How else should I remove it, then? Please provide good instructions, I'm new to Linux. Thanks!
Typed from my Pi
plugwash
Tue Oct 23, 2012 11:24 pm
sudo rm /var/lib/dpkg/updates/0056
Minor_Miner
Wed Oct 24, 2012 1:37 am
That worked, thanks!
chowanec
Sat Nov 24, 2012 8:08 pm
So -- seems like that worked for me too...
Now, can someone tell me what I just did? :)
-Chow
leo
Wed Sep 18, 2013 4:03 pm
found this thread when dealing with a similar problem, however I have no clue what to do in my case. Any attempt to use apt-get results in errors concerning 2 python packages, see below. Thanks for any help.
Regards, Leo
root@raspberrypi:/tmp# apt-get install python-numpy python-rpi.gpio
The following packages were automatically installed and are no longer required:
libblas3gf liblapack3gf
Use 'apt-get autoremove' to remove them.
Suggested packages:
python-numpy-doc python-numpy-dbg python-nose python-dev gfortran
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
194 not fully installed or removed.
Need to get 0 B/2,494 kB of archives.
After this operation, 14.3 kB of additional disk space will be used.
(Reading database ... 61956 files and directories currently installed.)
Preparing to replace python-numpy 1:1.6.2-1 (using .../python-numpy_1%3a1.6.2-1.2_armhf.deb) ...
Segmentation fault
dpkg: warning: subprocess old pre-removal script returned error exit status 139
dpkg: trying script from the new package instead ...
Segmentation fault
dpkg: error processing /var/cache/apt/archives/python-numpy_1%3a1.6.2-1.2_armhf.deb (--unpack):
subprocess new pre-removal script returned error exit status 139
Segmentation fault
dpkg: error while cleaning up:
Preparing to replace python-rpi.gpio 0.4.1a-1 (using .../python-rpi.gpio_0.5.3a-1_armhf.deb) ...
Segmentation fault
Segmentation fault
dpkg: error processing /var/cache/apt/archives/python-rpi.gpio_0.5.3a-1_armhf.deb (--unpack):
Segmentation fault
E: Sub-process /usr/bin/dpkg returned an error code (1)
plugwash
Wed Sep 18, 2013 10:37 pm
What is your /etc/apt/sources.list like?
Do you get a segfault if you run update-python-modules manually?
Can you successfully run python interactively?
Can you successfully perform the following imports when running python interactively?
import sys,os,shutil
from optparse import OptionParser
from subprocess import call
from py_compile import compile, PyCompileError
sys.path.append("/usr/share/python-support/private/")
import pysupport
from pysupport import py_supported,py_installed,py_oldversions
leo
Thu Sep 19, 2013 5:57 am
below are my results. Thanks in advance.
root@raspberrypi:~/bin# cat /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
root@raspberrypi:/# update-python-modules
Segmentation fault
root@raspberrypi:/#
root@raspberrypi:~/bin# cat test.py
import pysupport
root@raspberrypi:~/bin# python test.py
Segmentation fault
plugwash
Thu Sep 19, 2013 9:52 am
leo wrote: root@raspberrypi:~/bin# cat test.py
import pysupport
Segmentation fault
Can you try running those imports in interactive mode one by one so we can see which one is causing python to segfault.
leo
Thu Sep 19, 2013 2:38 pm
attaches are the results. Unfortunately I am not familiar with Python so I have no idea concerning the syntactical errors:
root@raspberrypi:~/bin# echo 'import sys' > test.py
root@raspberrypi:~/bin# echo 'import os' > test.py
root@raspberrypi:~/bin# echo 'import shutil' > test.py
Segmentation fault
root@raspberrypi:~/bin# echo 'from optparse import OptionParser' > test.pyroot@raspberrypi:~/bin# python test.py
root@raspberrypi:~/bin# echo 'from subprocess import call' > test.pyroot@raspberrypi:~/bin# python test.py
Segmentation fault
root@raspberrypi:~/bin# echo 'from py_compile import compile' > test.py
Segmentation fault
root@raspberrypi:~/bin# echo 'from py_compile import PyCompileError' > test.py
Segmentation fault
root@raspberrypi:~/bin# echo 'import pysupport' > test.py
File "test.py", line 1, in <module>
import pysupport
ImportError: No module named pysupport
root@raspberrypi:~/bin# echo 'from pysupport import py_supported' > test.py
root@raspberrypi:~/bin# echo 'from PySupport import py_supported' > test.py
ImportError: No module named PySupport
Return to “Raspberry Pi OS”
