jbudd
Solved: Problem with /etc/rc.local
Sun Nov 12, 2017 10:52 am
My recent installations of Raspbian September 2017 Stretch with desktop all seem to have a spurious new line in /etc/rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "chmod 777 /dev/ttyAMA0
exit 0" on success or any other
# value on error.
It doesn't stop the Pi from booting but since Bash throws an error my startup programs won't run.
Is this a bug in the release or something I'm doing wrong?
pcmanbob
Re: Problem with /etc/rc.local
Sun Nov 12, 2017 11:45 am
This is a copy of rc.local from a fresh install of stretch with desktop dated 2017-09-07
#!/bin/sh -e
# rc.local
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
exit 0
looks OK to me, if you have some thing different then I suggest you caused it while you were editing it.
if you cant see your error try posting a copy of your file using code tags to preserve formatting.
jbudd
Sun Nov 12, 2017 1:43 pm
It was an error in the Pi setup script I use.
